http://auszookers.com/forum/
Draining EFI Vitara Tank
http://auszookers.com/forum/viewtopic.php?f=37&t=34824
Author:  atari4x4 [ Thu Aug 09, 2012 11:50 am ]
Post subject:  Draining EFI Vitara Tank
G'day AZ people,
Quick noob question, what's the best way to drain pretty much a full tank from a Vitara...
Tried syphoning it but I can't get a hose past the filler neck & into the tank, just wondering if they have an anti syphon thing in the filler hose? As it seems to come to a dead stop just before the tank.
I need to remove the tank guard & was hoping to drain the tank so it wasn't so heavy with near enough 50+ litres in it plus I want to burn the fuel I steal in my wagon.
Any other pro tips would be handy.
Author:  barney7779 [ Thu Aug 09, 2012 12:02 pm ]
Post subject:  Re: Draining EFI Vitara Tank
If its EFI just disconnect the return line at the motor and run into a jerry can and start the engine
or could hook up a cheap elec pump on the pick up line from the tank and just pump into jerry can or straight into the wagon if you want
Would be a slow way of doing it but will get the job done
Author:  tanshi [ Thu Aug 09, 2012 12:04 pm ]
pretty sure they have a ball valve in the neck at the tank end.
Author:  atari4x4 [ Thu Aug 09, 2012 12:09 pm ]
bugger, figured they'd have an anti syphon in there. will have to figure a way to drain it as it's currently not running.
Author:  tanshi [ Thu Aug 09, 2012 12:13 pm ]
jack up drivers side a foot or so, maybe two. pull the filler hose of and syphon from there
Author:  Joe [ Thu Aug 09, 2012 12:25 pm ]
x2 on the filler hose that's how i got the fuel out of mine when i done my fuel pump :D stupid anti syphoning thing :roll:
Author:  atari4x4 [ Thu Aug 09, 2012 12:30 pm ]
i have a body lift so there should be a heap of room to work, thanks guys.
cheers
noobtari
Author:  BlueSuzy [ Thu Aug 09, 2012 1:21 pm ]
Pull it out, Pull pump out, Turn it upside down. Only way to get it dead empty.
The anti syphon thing can be a rollover thing too. It would help stop loosing all your fuel
Author:  atari4x4 [ Thu Aug 09, 2012 1:32 pm ]
tank doesn't need to be empty, just wanted to make it easier to remove the guard... CBF'd dropping the whole tank at the moment.
Author:  Reubs [ Thu Aug 09, 2012 4:29 pm ]
G'day AZ people,
Last time I took a tank out I tried siphoning and used 1/2" hose used in garden irigation systems. It's hard stuff so I could 'guide' the hose past the anti-siphon trap. Problem was the tank was too low for me to siphon with suction into a jerry can. Petrol doesn't taste too good and I after a couple of mouth-fulls I gave up! If I had a pump then I reckon it wouldn't be too hard.
Author:  buzbox [ Thu Aug 09, 2012 5:26 pm ]
just a thought..
Remove the rear bolts, loosen the front ones, enough squeeze the bolt between the guard and tighten then it back up, remove the front bolts.
no need to remove the fuel or tank..
Or run a strap under the tank and have the chassis support it while you undo the bolts.
Author:  atari4x4 [ Thu Aug 09, 2012 5:39 pm ]
buzbox wrote:
just a thought..
That's the plan & it's how it was installed, but with an almost bone dry tank it was still a handful. I'm not even going to attempt it with a full tank of fuel.
Rebus, I have a Jiggler... it's about 1/2" in diameter & pretty stiff fuel resistant hose, I could feel it & hear it coming to a stop as it hit the valve. I'll have another go & see if I can push past it.
I only want the fuel out as I'm a Jewlord & don't want to spend any of my Gypsy Gold on a tank of 98ron when I have a full tank sitting there going stale. :wink:
Author:  Reubs [ Thu Aug 09, 2012 8:46 pm ]
G'day AZ people,
Also, if you already have a tank guard on it, put a trolley jack under it, unbolt it, then lower it down and slide the tank in the guard off the jack (opposite side to fuel filler so you don't spill it!).
Or, if it's an EFI Vit, couldn't you take the fuel line off the regulator, direct it into a container and turn on the ignition to pump it out? Might take a while but it'd work wouldn't it?
Author:  shep [ Thu Aug 09, 2012 9:04 pm ]
10mm drill bit
Drill a hole in the lowest bit
Catch the fuel in a bucket
Patch the hole with kneedit or similar product
Bask in the glory of a job done with awesomeness.
Author:  atari4x4 [ Thu Aug 09, 2012 9:10 pm ]
you're an ideas man Shep. 8)
Author:  atari4x4 [ Sat Aug 11, 2012 8:44 pm ]
thanks for all the suggestions, tank is drained... got 55L out of it.
Author:  shep [ Sat Aug 11, 2012 8:55 pm ]
Did ya drill it?
Author:  atari4x4 [ Sat Aug 11, 2012 9:00 pm ]
there was no basking in the warm glow of awesomness :(
Author:  shep [ Sat Aug 11, 2012 9:10 pm ]
Girl.
