It is currently Sun Sep 20, 2026 3:01 am
Post Posted: Sun Aug 12, 2012 7:02 pm
How do ya get the big yellow fuse out off the fuse holder under the bonnet of a 1992ish vitara?
Post Posted: Sun Aug 12, 2012 7:27 pm
If it is the 80A one it is bolted in and doesn't pull out like the others.
Post Posted: Sun Aug 12, 2012 7:46 pm
Looks to be around 800 amp to me. Where is the bolt that holds it in?
Vehicle: LWB Sierra & XL7
Post Posted: Sun Aug 12, 2012 7:55 pm
It had me stumped for a while on mine too, But it should be on the side of the fuse holder. I think it's an 8 or 10mm.
It's the main fuse for the alternator yeah?
'92 Vitara & Camper trailer
Post Posted: Sun Aug 12, 2012 7:58 pm
Is that it there??
Post Posted: Sun Aug 12, 2012 8:05 pm
Yep that's it, the one with a nut jammed in it. No it wasn't me that put it there
Vehicle: SJ80, SE416
Post Posted: Sun Aug 12, 2012 8:06 pm
Yup - it's M6 so 10mm socket will fit. Gotta unscrew the fuse panel out to remove it.
It's a Male fusible link and looks like this:
It's the main fusible link - the smaller of the 2 leads from the battery +ve terminal go into this (bigger fat cable to starter motor solenoid). The alternator is connected to the LOAD side of the main fusible link and is un-fused from there to the alternator output post. There is a common busbar inside the fuse block from the LOAD side of the main fusible link which supplies the smaller fusible links which go to the fuse box inside the cab.
