It is currently Thu Sep 24, 2026 12:31 pm
Post Posted: Mon Aug 13, 2012 6:53 pm
So I am ready to get some more parts
I want front and rear diff lockers I am going mechanical (as I never really go more than 5km on the bitumen) ,
crawler gears and maybe a body lift if my tires don't fit
I already have 3" Calmini lift I also have 32' tires to go on too lj rims (I hope they fit ?)
In the not to distant future I want to put in a anvil front diff so dose that change what front diff loka I get.
I have a Apr 1990 JSATAO1C00129254 G16A Vitara.
So what parts do I need
I will be getting the parts from overseas
Can anyone help
Willo
Post Posted: Mon Aug 13, 2012 7:02 pm
These are the vitara crawler gears but they say they are for 1991 to 1998 vits
http://www.lowrangeoffroad.com/index.ph ... gears.html
Does any one know if a 1991 onwards vit transfer case will bolt onto a 1990 vit?
Post Posted: Tue Aug 14, 2012 2:24 pm
should do, if anything it may have a different spline count but im pretty sure that changes later.
if you get a 91+ case it should fit fine. so do you want to know what lockers you need? have a look on lowrangeoffroad.com, yours should be a 22spline front end.
Post Posted: Fri Aug 24, 2012 12:55 pm
so I'm still in the dark Low range cant answer my questions about the gears has any one fitted gears in a 1990 before, am I posting in the wrong area ?
Users browsing this forum: No registered users and 47 guests
