It is currently Wed Nov 04, 2026 4:24 am
Vehicle: 92 Suzuki Sierra
Post Posted: Fri Aug 24, 2012 2:40 pm
I'm just going straight to the noob section :thefinger:
Are there any special tools i should be getting to make life easier?
When i got the new tyres change last week the guy said they where shot and should be done, got the parts, just don't want to start something i cant finish this afternoon!
Post Posted: Fri Aug 24, 2012 2:45 pm
50mm hub socket and torque wrench make it more accurate and easier.
If you're handy, should take 30mins or so?
Vehicle: 85 Suzuki Sierra
Post Posted: Fri Aug 24, 2012 4:20 pm
Before you do it grab the top of the wheel and pull it out towards you, give it a big grab :). If they are "shot" or loose the wheel will have some slack/slop/movement in it when you pull on it and let it go. This is a good way to learn when they are wore out or need tightening. I suppose it doesn't matter if the car has weight on the wheel or not, if will have movement either way.
Remember what order things came out in and orientation :P
It takes me at least 30mins a side and I've changed mine a few times, just ensuring everything is done up correctly and lubricated.
Orange LWB Sierra
Vehicle: Yellow Ute
Post Posted: Fri Aug 24, 2012 4:44 pm
x2, after you use a torque wrench you realise how dodgey the torque chisel is.
Users browsing this forum: No registered users and 41 guests
