It is currently Sat Oct 31, 2026 2:36 pm
Vehicle: '93 1.3 Suzuki sierra soft top
Post Posted: Sat Aug 25, 2012 9:03 am
Ok so.. from time to time when i start up the sierra it does one of the following.
A. starts normally.
B. Starts but there is a weird descending buzz which goes on for about 3 secs after start up.
C. Doesn't start up just makes a loud grind noise.
Auto choke has been taken out btw.
Any ideas on what i can do to fix it?
Vehicle: 1985 Holden Drover
Post Posted: Sat Aug 25, 2012 9:19 am
Sounds like a similar problem i had, i just got a new starter off ebay and problem solved :D
Vehicle: 1985 lwb sierra UTE
Post Posted: Mon Aug 27, 2012 6:48 am
Check ur leads from ur batery to starter if the lead to the starter is frayed or loose it can cause that effect , also buddy try and tap her on the side if the starter don't smash it but just tap it a little and the solanoid I used to do that with my last zook every 6 months saved me some cash. And if u buy a new starter buy a g16 one as the fit the 1.3 and if u every part her out ill get some money back on it also id u do g16 conversion. U have a starter allready , there the same price so why not
Vehicle: SJ80, SE416
Post Posted: Mon Aug 27, 2012 11:31 am
x2, sound like the starter motor gear is sometimes not engaging fully on the flywheel and sometimes not disengaging properly.
A new starter should fix that (if flywheel gear is ok), or you could try taking the starter apart and re-greasing the sliding parts. Water/mud can get in there and gum it all up.
Users browsing this forum: No registered users and 37 guests
