http://auszookers.com/forum/
Removing vitara auto from car
http://auszookers.com/forum/viewtopic.php?f=37&t=35451
Author:  shep [ Mon Sep 03, 2012 2:34 pm ]
Post subject:  Removing vitara auto from car
How do I disconnect the shifter so I can drop the auto?
Author:  ball [ Mon Sep 03, 2012 2:44 pm ]
Post subject:  Re: Removing vitara auto from car
Author:  buzbox [ Mon Sep 03, 2012 3:03 pm ]
hahahaha
There's a little grub screw to remove the T handle isn't there??
Author:  shep [ Mon Sep 03, 2012 3:47 pm ]
buzbox wrote:
hahahaha
I want to disconnect the shifter from the gear box
Author:  tanshi [ Mon Sep 03, 2012 3:48 pm ]
its on a cable so i dont think it should stop you dropping the gearbox first
Author:  tonyevans [ Mon Sep 03, 2012 4:09 pm ]
According to the manual you disconnect the end of the cable and it comes free then lower away .................
Author:  shep [ Mon Sep 03, 2012 4:12 pm ]
Where do I disconnect it? The car is a mess and I can't see jack shit around the shifter
Author:  tonyevans [ Mon Sep 03, 2012 4:14 pm ]
At the gearbox end ................................ I think
Author:  tanshi [ Mon Sep 03, 2012 4:16 pm ]
from what i remember the cable runs to the bottom of the shifter and there is a clevis pin
Author:  tonyevans [ Mon Sep 03, 2012 4:29 pm ]
Manual says -
Author:  tonyevans [ Mon Sep 03, 2012 4:43 pm ]
Maybe this helps -
Author:  shep [ Mon Sep 03, 2012 5:27 pm ]
Cheers mate. I got the cable of he end of the shifter, hopefully it won't be stuck to anything else.
The vitara is a horrible thing to get in, worst stinking car I have had to deal with. It is truly revolting, can't believe the fella drove it around with a young baby in it. The sooner I can drag it out the back and set it on fire the better.
Author:  shep [ Sat Sep 08, 2012 4:51 pm ]
The poxy thing still won't come out. I will give it anouther try and if I can't get it the plasma is gunna get used
