It is currently Thu Oct 22, 2026 7:49 pm
Vehicle: 89 SWB vitara, g16b conversion
Post Posted: Sun Sep 09, 2012 10:41 am
Hey guys project shitara has become more reliable, now looking at lift and rubber. Currently on 235/75r15 on standard rims.
Leaning towards 30s. And probably m/t, maybe a/t.
Should have a 2 inch suspension lift soon, will consider body lift and dont mind giving the gaurds a flogging.
What rim width and offset do you vitara owners run? Assume mostly sunraysia rims, What width tyres have you gone for?
I have searched through endless vitara build threads and still stuck, any feedback would be great.
Cheers :)
Post Posted: Sun Sep 09, 2012 10:42 am
I'm running +5 offset XL7 rims, but zero offset would be ok aswell.
Vehicle: SJ51T
Post Posted: Sun Sep 09, 2012 10:58 am
I've run 15x7-12 and 16x7+5 on my old SE vitara. I think the +5 rims just rubbed on the chassis rails. The -12 took a fair bit of Hammering to fit.
Post Posted: Sun Sep 09, 2012 11:07 am
i run 15x7 with a -13 offset with 31's, also ran those rims with the 235's. most common offset for the vits i recon
Post Posted: Sun Sep 09, 2012 11:16 am
cheers guys, -13 is what ive come across most, shandy did you have to do much to fit them on -13s?
Post Posted: Sun Sep 09, 2012 4:14 pm
I also run 15x7 with a -13 offset with 31's om my LWB Vit.
I have a 50mm BL and about 50mm suspension.
Needed minor guard massaging.
Original owner had 32-s on 16's with a -13
he had little clearance issues only.
Post Posted: Sun Sep 09, 2012 4:42 pm
These were 15x7 F100 offset with 3 inch lift and no rubbing
Post Posted: Sun Sep 09, 2012 4:56 pm
nah not really mate, only got a small amount of scrubbing. about 5 mins with a hammer was needed.
oh and f100 and -13 offset are pretty much the same.
Post Posted: Tue Sep 11, 2012 9:05 am
If those are the same rims those KM2s I got off you are, it's a -6 offset. :)
Post Posted: Tue Sep 11, 2012 9:27 am
sideways wrote:
If those are the same rims those KM2s I got off you are, it's a -5 offset. :)
Yep the same :D
Post Posted: Tue Sep 11, 2012 10:19 am
Joe wrote:
Yep the same :D
Cool, it turns out I'm an idiot and they're -6. :oops:
If anyone cares, the specs are 15x7, -6 offset, CSA brand. I bought 2 from Tyrepower for $62 each. I didn't specifically ask but I did got the impression that black ones cost slightly more. :)
Post Posted: Tue Sep 11, 2012 5:22 pm
cheers for the input guys, looks like il keep an eye out for some, failing that il be off to tyrepower.
