| transfer case problems. http://auszookers.com/forum/viewtopic.php?f=37&t=35740 |
| Author: | bulladean_ [ Sat Sep 15, 2012 4:57 pm ] |
| Post subject: | transfer case problems. |
hi guys. Ive been having trouble get the sierra into low range. Its a 94 with original transfer case. It use to go into low range but it never really felt like it had engaged properly. Now i put it in and it pops straight out. Ive checked the mount and have done the oil in it but still wont stay in gear. Is it time for a rebuild ? |
| Author: | foolsp33d [ Sat Sep 15, 2012 5:08 pm ] |
| Post subject: | Re: transfer case problems. |
changed your shifter bushing? do you run a bodylift? is the xfer lever being forced out of gear due to bouncing off the tunnel? |
| Author: | bulladean_ [ Sat Sep 15, 2012 6:23 pm ] |
no body lift and it doesnt feel like the busher feels nice and tight. Its like there is somethi ng stoping it from going in |
| Author: | Fatzook [ Sat Sep 15, 2012 6:51 pm ] |
Take the rubber boot off the shifter and go for a drive. Probably worth popping the stick out and checking the bush as well. |
| Author: | bulladean_ [ Sat Sep 15, 2012 7:47 pm ] |
what am i looking for ? |
| Author: | Fatzook [ Sat Sep 15, 2012 10:22 pm ] |
The boot may be pulling the stick out of gear. And the bush may be cracked or have deteriorated. |
| Author: | bulladean_ [ Sat Sep 15, 2012 10:28 pm ] |
thanks heaps |
| Author: | zukmeista [ Sun Sep 16, 2012 6:44 am ] |
I had this problem, the long side mounting arm bent and caused the lever to hit the tunnel. |
| Author: | GeckoXL7 [ Wed Sep 26, 2012 1:36 pm ] |
Would be good to know what if you fixed it, have the same problem on my XL-7, but the Transfer case is different, gona take the Shifter out and see if everything looks good down the hole.. Originally i thought it was the transmission mount as the trans dropped a fair bit but wasn't the problem, just made it worse. Have to figure out how to remove the Transmission gear knob, stubborn thing! |
| Author: | bulladean_ [ Fri Sep 28, 2012 6:57 pm ] |
checked every last thing so i think im gonna get rid of it and put a new case in. |
| Author: | Gwagensteve [ Fri Sep 28, 2012 7:49 pm ] |
A rebuilt kit is a lot cheaper than a new case. That's even if there were any "new" cases - there are only old cases with rebuild kits in them. Steve. |
| Author: | GeckoXL7 [ Tue Oct 02, 2012 8:47 am ] |
mines now working fine, just cleaned out where the selector stick goes into and re greased it. There is also a circlip that can dislodge in the transfer case. Gear slipping out of mesh Worn shift fork shaft: Worn shift fork or synchronizer sleeve Weak or damaged locating spring Worn bearings on output rear shaft Worn chamfered tooth on sleeve or gear Missing or disengagement of circlip(s) |
