It is currently Sat Oct 17, 2026 5:43 pm
Vehicle: Vit swb 95
Post Posted: Mon Sep 17, 2012 1:10 pm
Hey guys,
I have been searching through here a bit, and also on some other sites.
I know what the offset is now :D but im wondering what will the best offset be for 31" tyres??
Post Posted: Mon Sep 17, 2012 1:14 pm
i run a -15 15x7, pretty sure most others run a similar size off set on the same size tyres.
Vehicle: Vit swb 95
Post Posted: Mon Sep 17, 2012 1:19 pm
Thanks for the quick responce atari4x4 :)
Vehicle: Vit swb 95
Post Posted: Mon Sep 17, 2012 1:23 pm
How do you rate the MTR's atari? Just had a look at them, they look pretty nice
Post Posted: Mon Sep 17, 2012 1:28 pm
old ones were awesome, not sold on the new ones & haven't run them... would throw my money at some km2's if i was to buy muddies today.
Vehicle: Vit swb 95
Post Posted: Mon Sep 17, 2012 1:35 pm
I heard KM2s werent good due to the load rating? (the role off the rims easy)
I was looking at either the Bighorns, KL71's or federal couragia's
Vehicle: ***
Post Posted: Thu Sep 20, 2012 11:35 am
15x8 need -19
Post Posted: Thu Sep 20, 2012 11:00 pm
Offset refs:
viewtopic.php?f=37&t=35593
viewtopic.php?f=37&t=35873
viewtopic.php?f=5&t=35773
For tyres:
viewtopic.php?f=5&t=31704
viewtopic.php?f=5&t=31439
Vehicle: '94 suzuki maruti
Post Posted: Sat Sep 22, 2012 8:26 pm
i run KM2's, run them at 10PSI, handle my rough driving with no rolling off the rim. i do a bit of rough sand driving, and dont really slow for corners as much as i should with low pressures.
Vehicle: Vit swb 95
Post Posted: Fri Oct 19, 2012 11:22 am
whats the best way to measure your offset?
I have some black desert rat rims, thinking about putting the 31's on them, and my 235's on my stock rims?
I was looking at the Speedywheels site and it seems like the black desert rats dont come in the -15 offset? only the white ones?
Post Posted: Fri Oct 19, 2012 11:28 am
EDIT can't find it... have search
there is a good write up on the speedy website.
Vehicle: Vit swb 95
Post Posted: Fri Oct 19, 2012 11:41 am
Yeah i know its there. That doesnt say anything about colours, and off the Speedy site, this seems to matter?
http://www.speedywheels.com.au/steel.htm
White says offset is ET-15, Black says ET5.... See below
STYLE | SIZE | OFFSET |STUD PATTERN |LOAD RATING
DESERT RAT - GLOSS BLACK DUAL SILVER PINSTRIPE |15x7.0| ET5 |6 | 1180kgs
DESERT RAT - OFF WHITE RED & GREEN PINSTRIPE |15x7.0|ET-15 |5x139.7 | 1180kgs
Edit:
That black is a 6 stud, my bad... no 5 stud on there. Site must not have all the sizes
Post Posted: Fri Oct 19, 2012 11:45 am
you asked about the easiest way to measure offset & speedy have both the backspace & offset measurement explained? :?
ET5 will be +5
get white ones & paint them black... problem solvered.
Vehicle: Vit swb 95
Post Posted: Fri Oct 19, 2012 11:47 am
Yeah i asked cause no info on my 15x7's lol Bob jane gave me no info when i got them either (+ i didnt ask)
So gotta measure,
Is it just from the back of the rim to where the studs arE?
Post Posted: Fri Oct 19, 2012 11:53 am
nope thats backspacing
Understanding Offset
Fitting a set of wheels with the correct offset is most important. Yet, because there are two commonly used (but different) methods for measuring offset, much confusion reigns.
At Speedy Wheels we understand both the "backspace method" and the "centreline method", so a short explanation of each may assist you in selecting the correct offset wheels.
Backspace Method: Measure from the extreme rear edge of the rim to the hub mounting face. Distance "A" in millimetres.
Centreline Method: Measure the overall width of rim (Distance “X”), halve this measurement to find centreline then measure backspace (Distance “A”).
Subtract “A” from “X/2” and you now have the centreline offset, which in Australia is written 35P or 10N to denote either positive or negative centreline offset. In Europe, centreline offset is usually written ET35 or ET-10 etc.
NOTE: The centreline offset measurement is “rim width dependant”, ie. as the width of the rim changes, so does the centreline offset, eg. if you have 14 x 6 wheels with 47P offset and would like to fit 14 x 7 alloys with the same backspace, then the same offset in 14 x 7 is 35P. In both instances, the backspace remains at 135mm.
copypastaed from the speedy site.
Vehicle: Vit swb 95
Post Posted: Fri Oct 19, 2012 11:57 am
cheers,
Well i just Called jobjane and asked about my history,
They told me i was given desert rats before and after i brought them,
Just got advised that they put on (King Wheels Terra 15x7.0 5/139) - They didnt know anything about the offset tho
Vehicle: Vit swb 95
Post Posted: Fri Oct 19, 2012 12:06 pm
Seem to be a -13 maybe.. wonder if its much difference between at -13 and -15 while running 31's
Post Posted: Fri Oct 19, 2012 12:09 pm
yeah 2mm :lol:
it will be fine
Vehicle: Vit swb 95
Post Posted: Fri Oct 19, 2012 12:16 pm
haha okay, ill chuck my AT's 235/75 r15 on my stock and save some moiney
Users browsing this forum: No registered users and 41 guests
