It is currently Wed Oct 14, 2026 3:41 pm
Post Posted: Thu Oct 04, 2012 9:11 am
After a short wheel on saturday where i bogged my car heavily ive been having steering problems.
I searched and found a few things.
I have taken damper of which made steering lighter but car still wouldnt return to centre after cornering
How do you check kingpins?
And ball joints?
And steering shaft u joint? Mine has body lift with bigger biscuit in it.
Going to replace all my oils and check wheel bearings. Do i need limslip oil for rear auto locker?
Could it be a swivel hub problem they arnt leaking or a break problem?
Thanks in advance
93 sierra 2"spring2"body 31,s & 4.9s
Vehicle: SJ80, SE416
Post Posted: Thu Oct 04, 2012 3:58 pm
Was the steering box submersed in water? These can fill up full of water - the oil cap has a breather in it.
Post Posted: Thu Oct 04, 2012 4:27 pm
yes for about 10 minutes i will drain it and fill it with gear oil tomorrow. good thinking reubs
Vehicle: 91 WT 1.6EFI
Post Posted: Fri Oct 05, 2012 7:47 am
fill it with bearing grease instead. That way when its really stuffed it won't run dry from the oil leaking out.
Post Posted: Fri Oct 05, 2012 8:35 am
How do you drain the steering box?
Post Posted: Fri Oct 05, 2012 8:45 am
I think the easiest way is to take it off, take the top bolt/top off and turn it upside down. Someone else can speak up if there is an easier way but thats how I did mine.
Users browsing this forum: No registered users and 73 guests
