| Seat belt question http://auszookers.com/forum/viewtopic.php?f=37&t=36983 |
| Author: | niran [ Thu Nov 08, 2012 8:59 pm ] |
| Post subject: | Seat belt question |
Hey everyone, At the moment I've got a narrow track 1985 Suzuki sierra and for anyone who is unaware the seat belts are the un-retracting style. I recall when I had a 1992 WT sierra that the seat belts where the retractable ones. By any chance can you put retractable ones into the NT or should I say 1985 Sierra’s ? Cheers, Ni |
| Author: | shep [ Thu Nov 08, 2012 10:05 pm ] |
| Post subject: | Re: Seat belt question |
They bolt straight it. I did a how to thread at few years ago. I suck at searching but so can't find it now |
| Author: | Fatzook [ Thu Nov 08, 2012 10:07 pm ] |
I believe so. Unless its a tin top ute. Not sure why you would want them though. They are a PITA offroad. |
| Author: | niran [ Thu Nov 08, 2012 10:53 pm ] |
shep wrote: They bolt straight it. I did a how to thread at few years ago. I suck at searching but so can't find it now Hey man, thanks for that info, did some searching and found your thread, however I have no opening there to put the retracting part :S mine is a hard top, if that would make any difference. I've uploaded a photo of your one in comparison to mine haha Attachment: comparison.jpg cheers |
| Author: | niran [ Thu Nov 08, 2012 10:55 pm ] |
Fatzook wrote: I believe so. Unless its a tin top ute. Not sure why you would want them though. They are a PITA offroad. I've got a tin top high roof and it seems to have the same issue.. haha that's true, but I getting it caught in my door when I close it |
| Author: | shep [ Thu Nov 08, 2012 10:56 pm ] |
Well you are screwed then. I have tossed the lap sash belts and now just have a lap belt. It's great for wheeling but proberbly not so great if I hit something |
| Author: | niran [ Thu Nov 08, 2012 11:05 pm ] |
shep wrote: Well you are screwed then. I have tossed the lap sash belts and now just have a lap belt. It's great for wheeling but proberbly not so great if I hit something Damit!! I might have to cut the panel.. See how it goes. Thanks for your help |
| Author: | shep [ Thu Nov 08, 2012 11:20 pm ] |
I wouldn't cut the panel as the mounts you need won't be there so ya won't be able to fit them anyway |
| Author: | niran [ Thu Nov 08, 2012 11:57 pm ] |
shep wrote: I wouldn't cut the panel as the mounts you need won't be there so ya won't be able to fit them anyway Ah true, Might just have to live with it then haha |
| Author: | Rossco [ Fri Nov 09, 2012 8:37 am ] |
Put a harness in...talk about a PITA |
| Author: | tonyevans [ Fri Nov 09, 2012 11:12 am ] |
I just dug around the wreckers and got a pair that just bolt straight on the outside of the pier - I can not remember which car they came from but there are quite a few like that. |
| Author: | Fatzook [ Fri Nov 09, 2012 12:05 pm ] |
tonyevans wrote: I just dug around the wreckers and got a pair that just bolt straight on the outside of the pier - I can not remember which car they came from but there are quite a few like that. This would require a mod plate. |
| Author: | Bruce [ Fri Nov 09, 2012 12:23 pm ] |
Fatzook wrote: tonyevans wrote: I just dug around the wreckers and got a pair that just bolt straight on the outside of the pier - I can not remember which car they came from but there are quite a few like that. This would require a mod plate. In Lighting Ridge |
| Author: | Fatzook [ Fri Nov 09, 2012 12:32 pm ] |
Bruce wrote: Fatzook wrote: tonyevans wrote: I just dug around the wreckers and got a pair that just bolt straight on the outside of the pier - I can not remember which car they came from but there are quite a few like that. This would require a mod plate. In Lighting Ridge In Perth...... where the OP is. |
| Author: | tonyevans [ Fri Nov 09, 2012 12:40 pm ] |
Fatzook wrote: tonyevans wrote: I just dug around the wreckers and got a pair that just bolt straight on the outside of the pier - I can not remember which car they came from but there are quite a few like that. This would require a mod plate. So would the other swap he is proposing - The car came with fixed belts. Never seen a REGO check look at the type of seat belt only condition and check to see if retractable click in if you pull then sharply. |
| Author: | Fatzook [ Fri Nov 09, 2012 1:00 pm ] |
tonyevans wrote: Fatzook wrote: tonyevans wrote: I just dug around the wreckers and got a pair that just bolt straight on the outside of the pier - I can not remember which car they came from but there are quite a few like that. This would require a mod plate. So would the other swap he is proposing - The car came with fixed belts. Never seen a REGO check look at the type of seat belt only condition and check to see if retractable click in if you pull then sharply. yep. It would too. |
| Author: | Bruce [ Fri Nov 09, 2012 1:30 pm ] |
Fatzook wrote: Bruce wrote: Fatzook wrote: tonyevans wrote: I just dug around the wreckers and got a pair that just bolt straight on the outside of the pier - I can not remember which car they came from but there are quite a few like that. This would require a mod plate. In Lighting Ridge In Perth...... where the OP is. |
