It is currently Sat Sep 26, 2026 2:11 pm
Vehicle: SJ51T
Post Posted: Thu Nov 15, 2012 2:53 pm
Anyone know where to get these from?
Checked locally and no one has anything similar enough to use.
Also, the embossed suzuki on the back gate is damaged :(. apart from Carry utes, is there anything else that has suzuki embossed that i could weld in. otherwise it'll just be ZUKI written on the back
Edit:
Found these to suit a landrover but at 55$ each, i'd need to make sure they fit :(
http://www.ebay.com.au/itm/Tailgate-Lat ... 744wt_1271
Post Posted: Thu Nov 15, 2012 4:24 pm
early hilux's had similar latches on the well bodies.
Vehicle: SJ51T
Post Posted: Thu Nov 15, 2012 4:35 pm
Thank you kind sir!
Post Posted: Thu Nov 15, 2012 4:44 pm
looking at the google, i'd say most well body lux's had that style of latch.
could you cut the ZUKI bit out & centre it & then fill the gap either side?
Post Posted: Thu Nov 15, 2012 4:53 pm
The older Rodeos have a similar latch..
Vehicle: SJ51T
Post Posted: Thu Nov 15, 2012 4:57 pm
Yeah I could. I'm not the greatest welder so i'm worried about making it look worse if I try to move it...
Sucks being shit at stuff like this :x
Post Posted: Thu Nov 15, 2012 6:33 pm
Its a shame you are doing this now. I have the same issue with my tray, and will be making replica sides for mine in the new year. The rear panel will have a shadow boxed 'SUZUKI' cutout with LED backlighting. Hard to explain, but its the rice equivelant to embossing. :wink:
Vehicle: SJ51T
Post Posted: Thu Nov 15, 2012 8:49 pm
Make me a set while you're at it :D haha
Yeah i'm not exactly sure what you mean but i'm sure it'll turn out nicer than what i'm doing!
Post Posted: Thu Nov 15, 2012 8:55 pm
I just checked my spare tailgate. The only letter that is damaged is the 'S' :cry: Otherwise I would have cut it out for you.
Vehicle: SJ51T
Post Posted: Thu Nov 15, 2012 9:22 pm
Ahhh that sucks! thanks for checking tho!!
Post Posted: Fri Nov 16, 2012 7:09 am
They look the same as the clips that hold soft top windscreens in place,
worth looking at wrecks, see if they are.
Post Posted: Fri Nov 16, 2012 9:48 am
I just went out and had a look, the handles are a fair bit shorter on the tray* but it could work! :D
*LJ81k tray, 1l Sierra windscreen thingys.
Vehicle: SJ51T
Post Posted: Fri Nov 16, 2012 9:54 am
Hmmm my uncle has those latches on his sierra farm hack! he doesnt really need a windscreen :D
Ill pick them up this arvo and see what i can do with them
Thanks!
Users browsing this forum: No registered users and 12 guests
