It is currently Wed Sep 30, 2026 9:43 am
Post Posted: Wed Dec 19, 2012 9:46 am
hey guys has any one looked into a power socket with a low voltage cut off??? thinking of putting on in the back of the jimny, Dont know much about them tho!
Post Posted: Wed Dec 19, 2012 10:42 am
I use one to stop my fridge draining my second battery. Cutout is 11.5v
Vehicle: SJ80, SE416
Post Posted: Wed Dec 19, 2012 12:22 pm
IMO, if you are powering a device from a cranking battery you need a cutout no lower than about 12.3V if you are worried about the lifespan of the battery.
If you are powering a fridge - most have low voltage cutout already. My Weaco has 2 cutout settings - the higher one is 11.7V and that is still too low for a cranking battery.
Also, do you need a socket? IMO power sockets don't belong in the back of cars if they are for semi-permanent connection. Even ruggedised power sockets seem to get loose or are easily knocked out.
IMO use an Anderson plug or if you are looking for a cheap solution - even insulated crimp connectors which is what I have for my fridge in the Vit.
I use figure 3 and figure 21 for the fridge in the Vit with the terminals arranged so the battery +ve side is female, battery -ve side is male and the wires are held together near the terminal so the battery side connections can't be connected into each other.
Post Posted: Fri Dec 21, 2012 5:12 pm
anywhere you can get a stand alone cut off???
Post Posted: Fri Dec 21, 2012 6:41 pm
A quick search of Jaycar found this...
http://www.jaycar.com.au/productView.asp?ID=AA0262
Post Posted: Sat Dec 22, 2012 9:06 am
Thanks Rebus! that will do perfect! cheers!
not sure on sockets yet. i think i will go a standard power set up..
its for charging Rc batterys, little cheep fridge + other stuff i haven't thought about yet
Users browsing this forum: No registered users and 58 guests
