It is currently Wed Sep 30, 2026 12:48 am
Vehicle: 1985 sj50v SWB
Post Posted: Sun Dec 16, 2012 12:39 pm
I have recently bought an lj50 to restore.
I'm stripping it down at the moment and I want to be gentle as to not create more work than necessary, as well as keeping it original.
Dash controls-
-pull knob switches with electrical connections ie. wipers, headllights...
- air controls (lever operated)
- ignition barrel
What is the correct removal procedure?
Any help or info on the matter or just lj50's?
Ryan
Post Posted: Mon Dec 17, 2012 8:53 am
they have little grub screws in the knobs, i screw those anhd then the knobs screw off counter clockwise.
Post Posted: Mon Dec 17, 2012 8:58 am
Ha ha I just worked it out, but one had to be drilled out.
Do you know how to remove the speedo cable from the transfer case? As well as the shifter?
Post Posted: Mon Dec 17, 2012 9:02 am
the speedo cable has a screw in part into the transfer. Just use pliers or multigrips and loosen it.
the shifter has a round spring loaded cap around the stick which needs to be pussed down and rotated before it will pop up.
Post Posted: Mon Dec 17, 2012 9:18 am
Rotated! I didn't try that.
I could see the nut but wasn't sure.
Is there a repair manual for LJ's?
All I have found is sales leaflets and owner manuals, and I'm not familiar with this engine set up and I'd love some info!
Post Posted: Mon Dec 17, 2012 9:24 am
you can get manuals for LJ50s on ebay some times.
there isnt an electronic version as far as i have found.
Post Posted: Mon Dec 17, 2012 9:45 am
That's a bummer, I'll have to keep an eye out.
Cheers tanshi
Post Posted: Mon Dec 17, 2012 9:55 am
Ask at a library, they have pretty much every book imaginable in the system. I know there's an LJ50 manual in the W.A system. They wont let you take it home but you can copy/scan whatever whilst you are there.
Post Posted: Tue Dec 18, 2012 12:06 pm
Good call!
Come to mention it I think I know a local second hand book shop that may have it.
I'll be checking the library this afternoon!
