It is currently Wed Sep 30, 2026 2:51 am
Post Posted: Wed Dec 19, 2012 11:39 am
How many teeth are on the crown wheel and pinion on a 3.7 sierra diff? I have a set of 3.7's and 3.9's but I'm not sure which is which (they are all in a parts bin I got with my old car).
Thanks in advance.
Donny.
Post Posted: Wed Dec 19, 2012 11:43 am
http://auszookers.com/forum/viewtopic.p ... &view=next
Vehicle: SJ80, SE416
Post Posted: Wed Dec 19, 2012 12:02 pm
Count the teeth and divide the numbers to determine the ratio...
Post Posted: Wed Dec 19, 2012 12:14 pm
Thanks for the help, are the pinion teeth the same in both??
Post Posted: Wed Dec 19, 2012 12:21 pm
they are the same number but different sizes i believe
Post Posted: Wed Dec 19, 2012 12:24 pm
Great! Which one will go with the 3.7 the larger pinion or the smaller pinion??
Post Posted: Wed Dec 19, 2012 4:20 pm
In my old cars a lot of r & p were marked to show what they match to.
Not checked zook stuff
Post Posted: Wed Dec 19, 2012 7:33 pm
I would think that larger pinion should go with the crown wheel that has coarser teeth which is the 3.7:1 pair.
Post Posted: Wed Dec 19, 2012 9:22 pm
You shouldn't mix and match your pinion and ring gears. They are a matched pair, and are worn in together. Mismatched R&P's canbecome noisey, and even fail earlier than otherwise expected.
Users browsing this forum: No registered users and 33 guests
