It is currently Sun Oct 04, 2026 5:21 am
Vehicle: Lwb vit, 31's big white fridge
Post Posted: Sat Dec 29, 2012 8:55 pm
Hey guys,
Pretty new to the forum
I used to drive a 99 manual jimmy with a 2 inch lift
Larger tyres, roof rack, snorkel
And a custom g16 baleno engine conversion.
I now drive a completely stock-
1993 vitara manual 4 door 1.6 EFI JLX estate
It's having all the goodies put on it in January in the shed
My question is
Have I got 5.12 diff ratios?
Are these perfect for the 31's I'm putting on?
I'm doing a lift kit and body lift and cutting gaurds etc.
Just need to know if putting 31's on ruins my road gearing.
And which ratio is best for the low range transfer case reduction gears?
Thanks you for your help
I eagerly await your replies. :peaceout:
Post Posted: Sat Dec 29, 2012 9:24 pm
I drive an auto 93 Vit 4 door with 31;s.
5:12 are the lowest thats easily available.
Yours is most likely 5:12 already.
5:8's would be great, available from a company in Turkey. 4x4art
Mine copes ok with the 31" tyres, but is not ideal.
Manual will be less nice I guess.
There is only one choice for tranny gears, 4;24 ratio.
Only lowers low range, high stays the same.
I have this fitted to mine, and I'm loving it.
Be able to go to 33;s easily in low range.
No hope in high range tho, 31's be the absolute maximum in my opinion.
Post Posted: Sat Dec 29, 2012 10:20 pm
Ok, so if I could source 5.8s I'd be sweet as?
Post Posted: Sat Dec 29, 2012 10:27 pm
i nominate you jimnynutter to be the test mule/guinea pig for the turkey 5.8's. Armsup
Post Posted: Sat Dec 29, 2012 11:22 pm
I second that. Someone's gotta take the plunge.
The other option for hi and low range gearing is the Trail Tough Undertaker, which is a bolt-on underdrive that slots between gearbox and transfer. Requires cusatom driveshafts, but it drops your gearing by 1.5:1 - enough for 35s apparently. Would be close to $2K by the time you got everything done.
Post Posted: Sun Dec 30, 2012 5:40 am
http://tr.4xfourart.com/4xfourarten/urunic.php?id=3
http://www.facebook.com/groups/142857621652/
Post Posted: Sun Dec 30, 2012 6:05 am
I believe the undertaker is no longer in production. A club member tried to buy one.
Post Posted: Sun Dec 30, 2012 4:24 pm
Bit apprehensive about those gears from Russia, there isn't much detail and im not fond of possibly wasting money.
Post Posted: Mon Dec 31, 2012 8:11 am
I think that gearing a vitara for on and off road use really requires the use of a sierra transfer case.
Drop 4.6 diff gears in the diffs (from a carby auto) and a sierra case with gears in it, and you'll have a 46% increase in road revs and very deep off road gearing. (31's are about 20% bigger than stock, so your cruise revs will increase about 20% overall)
I assume as you're in the ACT your driving is pretty steep and technical, so that might be the go.
Obviously this is an expensive fabrication project, but there's really no other option for a vitara unless you go to 5.83 diffs to offset high range and 4.24 transfer for low range.
Post Posted: Mon Dec 31, 2012 9:27 am
Seeing as I do some occasional distance trips. I kind of font want to upset highway rpm much more, so will going to 5.83 diff ratios and. 4.24 transfer gears be the best combination?
Post Posted: Mon Dec 31, 2012 9:35 am
I personally belive that would be perfect for 31 to 33 " tyres on a manual Vitara.
but the 5:8 and 5:7 diff ratios are hard to get or costly.
I run the 4:24 transfer gears and 31's,
I would not like smaller tyres, or low would be too low.
I be trying the 5:7 ratios from Europe after 2 years or so,
too many bills right now.
Post Posted: Mon Dec 31, 2012 10:37 am
Ok that's a big help. Thanks christover1
Post Posted: Mon Dec 31, 2012 10:44 am
If planning mostly touring, sand, desert etc,
I think with the 5:7 or 5:8 diffs you may not need the transfer gears.
Post Posted: Tue Jan 01, 2013 9:23 am
If you went with 5.7/5.8 diff gears, you'd want to have every possible upgrade done to the front diff. Breaking a housing and wiping out diff gears that aren't readily available would be annoying to say the least.
Post Posted: Tue Jan 01, 2013 10:40 pm
Yeah I'm canceling my lightforce order and spending the money on transfer gears and steel diff upgrade, keeping the 5.12 ratios and I'm going to see how long they last. If break something then, I'll try the5.83 or what ever the Russia one ares
Post Posted: Wed Jan 02, 2013 6:47 am
You will love it. :peaceout: Gearing rocks.
Post Posted: Wed Jan 02, 2013 2:25 pm
Then I look forward to it
Users browsing this forum: No registered users and 54 guests
