It is currently Mon Oct 05, 2026 12:09 pm
Post Posted: Wed Jan 02, 2013 9:29 am
Where have other people routed the filler pipe , it looks to me as it will have to go over the top of the chassis rail . And I would need a body lift for that , and I was hoping to get the car back on the road fairly soon . And I don't really want a body lift as I only run and need 30's. is there another way around this that I'm not seeing .
And the tank I have has no pump , dose the pump bolt straight in to the tank , or is there met to be some sort of cage that bolts in first
Thanks for any help .
Post Posted: Wed Jan 02, 2013 9:37 am
you either need a body lift. or you chop the rear floor and raise it.
i dont ssee any other way around it
Post Posted: Wed Jan 02, 2013 9:42 am
Dam , I did a fair bit of research but some how missed that bit
Post Posted: Thu Jan 03, 2013 6:16 pm
Get a coily sierra tank. It's a bolt in with the filler in the same spot. But it also has a swirl pot and removable 'lid' so you can install the vitara fuel pump.
Users browsing this forum: No registered users and 59 guests
