Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
jake.gilly
Vehicle: sj80 1996
 Posted: Sat Jan 05, 2013 8:50 pm |
Hey guys im putting it in this section as i dont know if its bieng answered before or where i can find a helping thread. Bassically my carby is reving really high between 2500 revs and the throttle is gone? if anyone can point me in the direction of a usefull thread detailing a rebuild or a detailed overview of how it works so i know where it is wrong that would be great. Cheers, jake
shark
Vehicle: 1984 NT High Top
 Posted: Sat Jan 05, 2013 8:56 pm |
Mine does the same exact same. I haven't found out what it is yet either.
christover1
Joined: Tue Jul 15, 2008 11:30 pm Posts: 8203 Location: Melbourne
 Posted: Sun Jan 06, 2013 6:50 am |
Sounds like auto choke is sticking. If its the same as early carbys, it works with water running through it. As radiator water warms up, it slowly removes choke. Often the water ways get blocked and need cleaning out. Or replacing of the mechanism.
christover1
 Posted: Sun Jan 06, 2013 6:53 am |
After fixing carby, before starting engine, make sure fuel system is clean, tank, filter/s changed, new fuel pump (old ones can lose diaphragm material that gets into carby) an extra filter in line after pump is helpful to prevent above issue.
jake.gilly
Vehicle: sj80 1996
 Posted: Mon Jan 07, 2013 1:12 pm |
Thanks for the help chris And that diagrm is mint. i think i may need to replace the mechanism as the spring does not spring back at all after the accelerator is released. I can manulally pull down the accelerator cable at the carby and it idles nicly but as soon as i rev it it does not pull back all the way when released and hence why it is reving high. bit of a pain hey shark haha
dono1
Joined: Fri Nov 26, 2010 10:57 pm Posts: 566 Location: Mid North Coast NSW
 Posted: Mon Jan 07, 2013 1:25 pm |
Remove the choke butterfly, it will take a bit longer to warm up in the morning though...
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 99 guests
