It is currently Fri Oct 09, 2026 7:13 am
Post new topic Reply to topic  [ 30 posts ]
Vehicle: 1.3 Tin Top
Post Posted: Sun Jan 06, 2013 4:16 pm
Since i bought the car the rear diff has always been noisy.
Just recently its gotten alot worse.
Theres more backlash.
Theres an oil leak from the left side.
the whine is now painful.
Luckily i made it back from sydney without failure.
I dont know if its related but the brakes are soft now aswell. and there is a abit of feedback through the pedal
at slow speed there is a fairly consistent pulse in time with a clicking noise from the left side.
Vehicle: Suzuki Jimny 2010
Post Posted: Sun Jan 06, 2013 4:59 pm
I'd guess wheel bearings are gone too?
Post Posted: Sun Jan 06, 2013 5:03 pm
thats what im thinking aswell
Post Posted: Sun Jan 06, 2013 5:18 pm
Pull it out to check it.
Buy new wheel bearings before you do it.
Post Posted: Sun Jan 06, 2013 5:21 pm
X2 plus new axle seals, brake shoes and wheel cylinders.
Post Posted: Sun Jan 06, 2013 5:53 pm
Or convert to rear discs if that's something you desire.
Post Posted: Sun Jan 06, 2013 6:29 pm
Oh. Ive always had axle seals in the kits ive had.
Yeah, get the seals too
Post Posted: Sun Jan 06, 2013 6:44 pm
Yeah im considering doing vit brakes up front and rear discs. Is the conversion worth it?
What should i be looking for in terms of diff wear?
Post Posted: Sun Jan 06, 2013 7:59 pm
That oil leak past the seal will be all over your rear disc/drum... may explain the lack of brakes. And lack of fluid in the diff will increase noise. I rebuilt the NT rear drums for around a hundy - new slaves, shoes source 1 drum within spec and skim both. Wheel bearing from a gd brand cost around the same. I pulled the axle I thought was loose - did that 1 and popped the other side out of interest as theres no point toppin the diff up twice and the other side was fully fkd. Have a full front end and a spare pair of front discs so its worth it to me to do a disc rear.
Post Posted: Sun Jan 06, 2013 8:05 pm
Ill do the wheel bearings and seals for now and start gettin money and parts for rear disc and vit front.
Post Posted: Sun Jan 06, 2013 8:12 pm
If the drums are poked its worth spending 100 on them bringing them back to spec for the now - the big killer is mud. If you can afford to have it off the road you can make the rear disc brackets for far less than the few hundy plus asking price, I have some drums parted off and some plate sittin under my bench at wk awaiting my interest/ along with F+R axles 2diffs calipers etc... ha ha
Post Posted: Sun Jan 06, 2013 8:16 pm
If you have a rear diff in good condition with good bearings id be interested
Post Posted: Mon Jan 07, 2013 1:53 pm
Shipping from NZ may be a deal breaker... The rear I have is a bit stuffed - I am not sure if theres anything of worth in it but it came with the rest of the parts and havnt looked at it too closely as I was planning on buyin new side gears for a front one or a locker with couplers.
Post Posted: Mon Jan 07, 2013 1:55 pm
oh didnt realize you were in NZ.
I got new bearing kit on the way. will see how everything goes. if the diff is still as noisy as it is i will save as hard as i can for a locker and get it done by a shop.
Post Posted: Mon Jan 07, 2013 2:07 pm
Got my zook with some garden hose breathers into the cab, I know my rears on its way out but the hose just ampliflies the sound - put my finger partway over the end at 100 k and the noise all but stops - you could also try the thickest diff oil you can buy to quieten it down (not a real fix but works for me for now) FYI I am currently feeding the g13 the thickest cheapest oil money can buy as its gettin more and more thirsty...
Post Posted: Mon Jan 07, 2013 6:24 pm
it has 90/140 well had... until the seal fkd itself today and the oil went all over everything.
Post Posted: Mon Jan 07, 2013 6:33 pm
check ALL your uni joints while you're there!
Post Posted: Mon Jan 07, 2013 6:56 pm
yeah ALL the unis are in good nick. except the steering shaft ones. there all pretty much new
Post Posted: Mon Jan 07, 2013 7:14 pm
Which seal died? If it is near the wheels it will be failed wheel bearings.
Post Posted: Tue Jan 08, 2013 8:47 am
left side axle seal. I started tearing everything down. diff has made a freakin mess of the brakes.
Has anyone got any tips for getting the axles out?
Post Posted: Tue Jan 08, 2013 1:36 pm
I made some ugly slide hammers from scrap 1 for the drum and 1 for the axle. I hear you can rebolt the rim on and work the drum off / this is the hard part esp if they are worn. If the handbrake is on the axle it needs to be backed off - Tcase dont worry. If your stuck maybe take the shoes off and refit drum + wheel, unbolt slave cyl fittings(clamp hose) undo 4 bolts on housing flange and it should pop off - more or less. Do 1 side at a time if your redoing the drums so you can look on the other side to see how it goes together. All this is my uneducated opinion / I am one that can fiddle with stuff but struggles to remember exactly what I did
Post Posted: Tue Jan 08, 2013 3:07 pm
viewtopic.php?f=17&t=19477&hilit=axle+puller
viewtopic.php?f=5&t=26322&hilit=axle+puller
Post Posted: Tue Jan 08, 2013 8:12 pm
Ok thanks for all the helps guys.
Now im faced with the problem of getting the new bearings on?
The old ones were proper effed.
the left one resembled something of robot vomit
Post Posted: Tue Jan 08, 2013 8:19 pm
bearings & collars in the oven & axles in the chest freezer. if your bearings have the dust seal on them remove them before cooking.
Post Posted: Tue Jan 08, 2013 8:45 pm
OK thanks!! I'll give it a crack. The kit I got only came with axle seals???
Post Posted: Tue Jan 08, 2013 8:47 pm
NFI, i don't care much for those old shitters. :P
have a search im sure there are a couple threads on wheelbearings :wink:
Post Posted: Tue Jan 08, 2013 8:50 pm
Cheers.
Post Posted: Wed Jan 09, 2013 12:05 pm
Worked a treat. Thanks atari :)
Post Posted: Wed Jan 09, 2013 12:25 pm
awesome, did they just drop straight on?
how long & what temp did you bake the bearings for & how long did you have the axles on ice?
i'm guessing you had a chest freezer, cause my axles have no chance of fitting in my freezer. :(
Post Posted: Wed Jan 09, 2013 5:52 pm
yeah nice big freezer. turned it right down. about -20.
bearings at 200 for 10 mins or so.
couldnt get the collars on even at 300.
left the axles for half hour.
and the bearings dropped straight on and almost imediately locked in plce.
Users browsing this forum: Google [Bot] and 115 guests
