The panel work is a bit different in shape and there's no need for the indicators/parkers, but the mounts should be pretty similar from memory - it just might look a bit ghetto.
just wondering if a nt bullbar will fit a coily or will i need to make new mounts
It should fit. The chassis mounts are the same. You will have a small gap between bar and front clip under the headlights due to the coily's tapered front but it's not too noticable.
Users browsing this forum: No registered users and 68 guests
