It is currently Sat Nov 14, 2026 11:10 am
Vehicle: chick magnet coily
Post Posted: Wed Dec 26, 2012 11:15 am
hi guys just a quick question (hopefully)...
just wondering if there is any difference between wide track cr-mo cv's and coily cv's
not the axles just the cv's...would there be any chance i could machine some down to suite
a coily? has anybody tried it? i am just wondering as i have acess to mills/lathes and was wondering
if it was possoble.
thanks in advance max
Post Posted: Wed Dec 26, 2012 8:56 pm
No point if you are running standard axles.
Post Posted: Thu Dec 27, 2012 8:42 am
X2. Inner axles will then become the weak link.
Post Posted: Sat Dec 29, 2012 6:51 am
Ok thanks guys
Post Posted: Sun Dec 30, 2012 11:31 am
And coilys run vit hubs not sierra hubs
Post Posted: Mon Dec 31, 2012 8:13 am
So the stub axle is a different length. This can be fixed with spacers between the hub and freewheeling hub, but it's one more issue.
Post Posted: Tue Jan 01, 2013 8:09 am
thanks guys
Vehicle: Daisy
Post Posted: Sat Jan 05, 2013 8:07 am
Couldn't you just change the ends of the coily diff to WT knuckles/spindles and hubs so the wt axles fit?
You're still not gaining much if anything you'd be better doing the full diff swap wouldn't you?
Post Posted: Sat Jan 05, 2013 9:30 am
What will you do for steering? Coily diffs/knuckles run the tie rod behind the diff to make room for the panhard up front.
Post Posted: Sat Jan 05, 2013 12:43 pm
nothing fits a coily
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Mon Jan 14, 2013 4:39 pm
Put in a complete jimny diff/housing and buy chromolly axels and cvs.
Panhard will be in the right place then, the other mounts for the coils and arms probaby just need a little moving to fit.
Post Posted: Mon Jan 14, 2013 5:21 pm
That much hastle, you might as well go WT diff pompoms pompoms
Post Posted: Mon Jan 14, 2013 5:37 pm
And waste a perfectly good WT diff!?
Post Posted: Mon Jan 14, 2013 5:45 pm
:rofl: :thefinger: :mrgreen:
Post Posted: Mon Jan 14, 2013 7:20 pm
Seems like a sideways step to me. Jimny has all the same issues as the coily.
Complete swap to WT, or just live with your coily gear. Only 2 options IMO.
Vehicle: 6.5s, gti, 31 extremes
Post Posted: Tue Jan 15, 2013 12:43 pm
wat if u were to run a nt rear centre up from with custom made axles made to suit a wt cv, run a spacer on the hub as mentioned above to keep steering gear etc? then u could also run a lokka up front
Post Posted: Tue Jan 15, 2013 12:55 pm
Once more for those who are having issues with spacial awareness. :thefinger:
You can't change to a low pinion leafy centre without moving the tie rod to the front side of the diff. This can't be done without major mods to the panhard bar, and locating brackets, as the drag link, tie rod and panhard are all competing for the same VERY limited space.
EDIT.
The ONLY option to run the WT CRMO cv's would be a custom 22 spline inner axle to suit the coily HP centre, and spacers for the hub.
Post Posted: Tue Jan 15, 2013 12:58 pm
EDIT.
It didn't take that long to do :thefinger:
Post Posted: Tue Jan 15, 2013 1:17 pm
Doh! Beaten by FZ's lightning fingers!
The tie rod is behind the axle and won't clear the pinion. That's why a coil front is high pinion.
Post Posted: Tue Jan 15, 2013 1:35 pm
highsteer arms pointing backwards :)
Post Posted: Tue Jan 15, 2013 2:05 pm
Just do what the lux guys do, make up a homemade y-arm high steer by welding a 2nd arm upside down on top of the stock arms :peaceout:
Post Posted: Tue Jan 15, 2013 3:17 pm
:shocked: :shocked: :shocked: :shocked:
Post Posted: Tue Jan 15, 2013 9:00 pm
Its called a Y-Arm and they do it to eliminate the crappy J-Arm setup they have stock and alot of buggies not running full hydro do it because the high steer arms make the drag link and tie rod sit too high and it hits the chassis rail when the cars are built low. Superior Engineering actually still sell them.
http://www.superiorengineering.com.au/p ... ts_id=2816
Post Posted: Wed Jan 16, 2013 4:58 am
Buggy would be ok I guess. I can see how that wood work. Excuse my ignorance pompoms
Post Posted: Wed Jan 16, 2013 6:31 pm
this kinda seems doable then
Post Posted: Wed Jan 16, 2013 6:41 pm
It is...look at the front of my Coily pompoms
viewtopic.php?f=4&t=8149&start=840
Pics down the bottom :peaceout:
Users browsing this forum: Google [Bot] and 22 guests
