It is currently Sat Nov 14, 2026 4:13 pm
Post Posted: Sun Jan 20, 2013 11:38 am
Hey guys. What is this?
I noticed on the other side is a pin that is up against the back of the ring gear. Just curious what it does and how it would affect the (dis)assembly of the centre compared to the Sierra centre.
Post Posted: Sun Jan 20, 2013 12:00 pm
IIRC That's a load bolt - it's there to prevent excessive distortion of the ring gear - it shoudn't affect disassembly, It should just run very close to , but not in contact with, the ring gear. What model did that centre come from - GV?
Note though, I haven't disassembled one myself, I'm just going from what it is/does. I guess you'd just have to set it up so the clearance was the same as it is now. Might actually be a useful guide for dropping the centre back in.
Post Posted: Sun Jan 20, 2013 12:14 pm
I figured it would be something odd like that.
I'm not sure, Darkhorse may have a better idea. Although, it is a 12 bolt ring gear if that helps.
Thanks Steve.
Post Posted: Sun Jan 20, 2013 7:08 pm
AFAIK it's a stock SV620 manual.
Post Posted: Sun Jan 20, 2013 8:07 pm
FYI 10 bolt rear 5.12's, don't have that load bolt... might be why i've lunched one or two in my previous live :P
Post Posted: Mon Jan 21, 2013 11:55 pm
jimny front has the same! well the one I have here does.
Post Posted: Tue Jan 22, 2013 6:35 am
The LJ diffs I had in my Sierra had them, too
Post Posted: Tue Jan 22, 2013 8:17 am
yep, lj 50 diffs had them
Users browsing this forum: No registered users and 34 guests
