| Simple questions I don't know the answer too http://auszookers.com/forum/viewtopic.php?f=37&t=38639 |
| Author: | shark [ Tue Jan 29, 2013 9:59 am ] |
| Post subject: | Simple questions I don't know the answer too |
Hey guys, I'm pretty sure these are simple questions but I don't know the answers as I'm pretty new to sierras. I have a 1984 NT sierra. Do WT sierras come with retractable seat belts?? Is it an easy swap if so. Can the stupid passenger side seat rail be swapped for one like the drivers side. Do WT side mirrors bolt straight in Cheers I am advance |
| Author: | Fatzook [ Tue Jan 29, 2013 10:03 am ] |
| Post subject: | Re: Simple questions I don't know the answer too |
shark wrote: Hey guys, I'm pretty sure these are simple questions but I don't know the answers as I'm pretty new to sierras. I have a 1984 NT sierra. Do WT sierras come with retractable seat belts?? Is it an easy swap if so. Can the stupid passenger side seat rail be swapped for one like the drivers side. Do WT side mirrors bolt straight in Cheers I am advance 1. Yes. And it depends whether or not you have the cavity in the base of the B-pillar or not. If there is a black blanking plate there, retractable units from a later model will fit straight in. 2. Whats wrong with your pass-side seat rail? Rat trap type? 3. Perhaps. But its an easy mod regardless. |
| Author: | shark [ Tue Jan 29, 2013 10:05 am ] |
Yeah the passenger side seat rail is that weird folding type. |
| Author: | Fatzook [ Tue Jan 29, 2013 11:52 am ] |
A later model seat and rails should swap straight in. |
| Author: | Scrawny [ Tue Jan 29, 2013 11:57 am ] |
WT mirrors should bolt straight on |
| Author: | Blkfxx [ Tue Jan 29, 2013 4:43 pm ] |
WT mirrors DO bolt on. |
| Author: | want33s [ Tue Jan 29, 2013 7:04 pm ] |
As Pete said, some NT's have a blanking plate held in with 4 screws. Remove the screws, fit retractor... Easy as... If you don't have the blanking plate then fitting retractors will still be possible bit it WILL be a drama, both physically and legally. WT mirrors definitely fit NT. Your NT will have a flat floor on passengers side, hence the different seat rails to drivers side. If you can get access to a WT wreck you can drill out the spotwelds of the passsengers seat mounts and weld them all into your car. |
| Author: | shark [ Wed Jan 30, 2013 9:10 am ] |
That's all brilliant info guys, cheers. |
