Vehicle: 1984 NT High Top
Posted: Mon Feb 04, 2013 7:11 pm
Okay bare with me.
I have made the necessary modifications to the radiator support to enable to fitment of the factory power steering pump and air con compressor.
What I was to know is if I connect the high and low pressure pipes together to make one continues loop till I can afford a steering box will that work??
I figured it would work under pressure not volume so might be okay.
Joined: Sat Dec 11, 2010 10:03 pm Posts: 2261 Location: Gold Coast
Vehicle: Daisy
Posted: Tue Feb 05, 2013 8:18 am
Surely you could do as you said but connect both hoses to the res, so you're pumping fluid but it's not just one pipe that is short and cycling really quickly?
Users browsing this forum: No registered users and 35 guests
