| bullbar will it fit http://auszookers.com/forum/viewtopic.php?f=37&t=38956 |
| Author: | jubz [ Tue Feb 12, 2013 6:50 pm ] |
| Post subject: | bullbar will it fit |
Will this bar fit on a 1994 w/t 1.3 its off an 89 1.3 unsure if its w/t or n/t can you guys help ?tryed to add a pic but cant how can i work out if its a nt or wt |
| Author: | Scrawny [ Tue Feb 12, 2013 7:04 pm ] |
| Post subject: | Re: bullbar will it fit |
Doesn't matter, it will fit |
| Author: | jubz [ Tue Feb 12, 2013 7:34 pm ] |
thanx mate Some one told me a nt bar wont fit a wt so i wasnt sure |
| Author: | Scrawny [ Tue Feb 12, 2013 7:43 pm ] |
The only difference between the NT and WT chassis is the spring spacing. The chassis rail ends are the same. I can't remember if the outriggers are the same but they usually get cut off anyway |
| Author: | Fatzook [ Tue Feb 12, 2013 8:03 pm ] |
Sorry Scrawn, but there is a difference. Depending on what brand of bar it is, it may bolt to the outside of the chassis rail on a NT. This won't work on a WT because there is a supporting bracket for the outboarded shackle hangers in the way. We really need pics to be certain. |
| Author: | Scrawny [ Tue Feb 12, 2013 8:10 pm ] |
Argh!! Second time in my life I've been wrong Can the mounting bracket be modified/cut to fit? Doesn't matter for the OP anyway as they are both WT (unless its a Maruti or something weird) |
| Author: | Fatzook [ Tue Feb 12, 2013 8:12 pm ] |
Scrawn wrote: Argh!! Second time in my life I've been wrong Can the mounting bracket be modified/cut to fit? LOL. You may be right, but without more info (ie. pics) from the OP, its just an educated guess. |
| Author: | tonyevans [ Wed Feb 13, 2013 12:41 pm ] |
I had to make modified brackets to fit a WT bar to my 1984 NT. |
