It is currently Sun Oct 04, 2026 10:31 pm
Post Posted: Thu Feb 28, 2013 3:34 pm
did suzuki change the seat rail's much in sierras?
will tin top 1ltr jobs fit my 90's widetrack?
Post Posted: Thu Feb 28, 2013 3:47 pm
i think the fit. through out the leafy years. but yes they changed them alot
Vehicle: Drover pickup turk
Post Posted: Thu Feb 28, 2013 4:30 pm
I know that with my ute there are 2 different bolt holes for the rear of the rails, One in line with the rail and one offset.
However, With my dads WT it only has the ones inline with the rail.
IE I can't put my ute seats into the WT because they use the offset mount but I can fit the WT seats in my ute.
I like the tuna here
Post Posted: Thu Feb 28, 2013 7:23 pm
Interesting.. what are the easiest ones to fit aftermarket seats to? i don't have any rails at all.
Post Posted: Thu Feb 28, 2013 7:31 pm
I think with some re drilling the driver's side rails from any sierra will fit any other (leaf) sierra. Nothing fits a doily. :D
I would say if you have sliders (i.e not fixed ute seats) then they will swap over. The passenger side won't - the front two bolts will line up, but new rear holes will need to be drilled to fit the hinge style 1.0 passenger side seat to a 1.3 floor.
Post Posted: Fri Mar 01, 2013 7:38 am
Ok no worries, so if i was to look for a set of rails what should i look for to make fitting of aftermarket seats nice and easy?
Post Posted: Fri Mar 01, 2013 5:27 pm
Everything is the same width, Just different mount points on the floor.
So either way you go will be the amount of fab work.
Users browsing this forum: No registered users and 52 guests
