It is currently Wed Oct 07, 2026 9:18 am
Vehicle: 96 tin top sierra 31's omes
Post Posted: Wed Mar 06, 2013 6:22 pm
Hey I have 4 driving lights on my sierra stock elec system...
I am running 1 relay currently
As I'm off road with the rpms low it appears I am drawing all my power and my radio and elects trip.( turn off and back on).
Is this because I'm am idiot for running 1 relay?
Or can't the stock system handle?
I'm not to cluey with electronics so if you could reply at a kindergarten grade that would be greatly appreciated!!
Thank jake!!
My build thread
viewtopic.php?f=4&t=37289
Post Posted: Wed Mar 06, 2013 6:25 pm
What size are the lights?? Type?? 2 relays would probably be better
Post Posted: Wed Mar 06, 2013 6:31 pm
im assuming halogen globes, so 400w (33amp) total, which would be pushing it with the relay, but certainly pushing the alternators ability. With head lights as well ignoring the stereo and anything else electrical thats around 43amp of draw, it's no wonder it's struggling. Looking at converting to hid or led if you're not running either at this stage, along with alternator upgrade which is done to death (along with upgraded headlight looms from the boss man as well(
Post Posted: Wed Mar 06, 2013 6:42 pm
Awesome thanks for the quick reply!! 2 larger one ad 2 smaller rectangular lights don't know if that helps... I will try get a photo for you guys..
This maybe a stupid question but how would I wire a second relay?
Separate? Or using same wires?
Post Posted: Wed Mar 06, 2013 6:55 pm
Second relay is easy. You can just split the trigger wire (from headlight) to run both relays. Run another power from the battery and then run two lights off each relay.
This won't fix your issue tho. You need to upgrade to a bigger alternator or use less lights/stereo
Post Posted: Wed Mar 06, 2013 6:59 pm
Noo I need to be blind and def at the Same time!
Haha looks like its upgrade time !
Vehicle: Suzuki Jimny 2009
Post Posted: Thu Mar 07, 2013 7:48 pm
To prove that overloading is the problem disconnect two of the lights and see if the problem goes away.
Users browsing this forum: No registered users and 53 guests
