It is currently Sat Nov 14, 2026 12:17 pm
Post Posted: Fri Mar 08, 2013 6:31 pm
Offered a body and chassis that is stamped 2/88.
The guy thinks it's a WT but I thought Suzuki changed 88.5 (July 1988?).
It's sitting in mud and long grass with no diffs, top or dash (tub and chassis mostly).
It has white plastic flares.
When did sierra change to WT in Australia?
Thanks for your time.
Post Posted: Fri Mar 08, 2013 7:52 pm
Could be early WT, they used color matching plastic flares.
Only way to be sure is check spring hangers on the rear.
If they in line with chassis it is nt,
if wider apart/sticking out from chassis then it is a wt.
Post Posted: Sat Mar 09, 2013 11:50 am
My Jap WT is a Jan 88
nfi why people call it 88.5, Im guessing because it runs few NT parts as a crossover model, NT tail shafts and flanges etc. no big deal
The width of a WT plastic flare is about 3". These plastic flares also have a flat moulded section that travels over the top arch of the flare.
NT are much thinner in width.
Best way to check is the spring perch under the front of the chassis. Directly under the 100x50mm chassis rail is a NT, offset to the chassis rail is a WT
Jan 88' WT Plastic Flare
91' WT Metal Flare
Post Posted: Sat Mar 09, 2013 8:10 pm
Hey Thanks,
I see the difference in the plastic/metal flares.
I'll check the flares.
Vehicle: 85 ' Drover
Post Posted: Mon Mar 11, 2013 10:45 am
my drover (1985) is as far as i can tell is a NT
the rear springs have 2 spring hangers (obviosly) one at each end.
The rear most one, is inline with the chassis rail.
However the front spring hanger (on the rear spring), is outside the chassis rail.
Post Posted: Mon Mar 11, 2013 7:50 pm
Correct
Should be called, Shackle hanger
Post Posted: Sun May 05, 2013 10:02 pm
It's a WT
Thanks for yor help
Users browsing this forum: No registered users and 33 guests
