| hub nut tool http://auszookers.com/forum/viewtopic.php?f=37&t=39789 |
| Author: | Ausuki [ Sat Mar 23, 2013 5:49 pm ] |
| Post subject: | hub nut tool |
I'll be needing a hub nut tool soon due to a cracked cv boot, is there a cunning diy option or should i just order one from our kiwi cousins? http://www.ebay.com.au/itm/111035501004 ... 1438.l2649 cheers |
| Author: | Rusho [ Sat Mar 23, 2013 5:55 pm ] |
| Post subject: | Re: hub nut tool |
That bloke is one of our resident machinist/parts makers. Very good quality. The other option is a pin punch/hammer. But the hub tool would be much, much better |
| Author: | Ace [ Sat Mar 23, 2013 6:36 pm ] |
Is that ben_t by any chance?? I think its a gd price when you do a time cost thingy - and you can rent it to your mates for a 6 pack |
| Author: | Rusho [ Sat Mar 23, 2013 6:52 pm ] |
Yep. That's him. Another positive is being able to get an absolute spot on tension to do them up also |
| Author: | want33s [ Sat Mar 23, 2013 7:38 pm ] |
Rusho wrote: Yep. That's him. Another positive is being able to get an absolute spot on tension to do them up also Don't Vitaras(/coilies) use a cassette bearing that you do up as tight as you can then another half a turn not the old leafy Sierra tapered bearings that need pre-load set correctly? |
| Author: | royce [ Sat Mar 23, 2013 10:23 pm ] |
want33s wrote: Rusho wrote: Yep. That's him. Another positive is being able to get an absolute spot on tension to do them up also Don't Vitaras(/coilies) use a cassette bearing that you do up as tight as you can then another half a turn not the old leafy Sierra tapered bearings that need pre-load set correctly? there is a specified torque for the nut, its high but still specified the engineers cant devise the bearings preload without saying how much to squish it |
| Author: | Ausuki [ Sun Mar 24, 2013 5:01 am ] |
ok thanks. ill start saving/collecting, i might as well do the springs and struts at the same time. I am beginning to think a rattle gun would be handy for the hub nut and the strut tops, are electric (240v) rattle guns worth the trouble? was looking at these http://www.ebay.com.au/itm/NEW-UNIMAC-2 ... 2573ddbf03 |
| Author: | royce [ Sun Mar 24, 2013 6:45 am ] |
rattle gun is good for the strut tops, dont use it on the bearings! |
| Author: | Ausuki [ Sun Mar 24, 2013 9:49 am ] |
royce wrote: rattle gun is good for the strut tops, dont use it on the bearings! |
