| Clutch problem http://auszookers.com/forum/viewtopic.php?f=37&t=39833 |
| Author: | Moe101 [ Mon Mar 25, 2013 2:30 pm ] |
| Post subject: | Clutch problem |
Hey guys just wondering if anyone has Had this problem My clutch got really hard after two offroad trips it kind of feels like I'm pressing the brakes I tried adjusting the nut on the cable helped a bit but feels like the car has trouble selecting gears from 1st to second Any help would be much appreciated cheers |
| Author: | tonyevans [ Mon Mar 25, 2013 2:33 pm ] |
| Post subject: | Re: Clutch problem |
Car?............ |
| Author: | Ace [ Mon Mar 25, 2013 2:59 pm ] |
Cable clutch - must be a real zook..... any chance you drove through some muddy water and its got into the sleeve or possibly pooed up the pivot pin on the gear box or maybe in the firewall rubber. My guess is its in the cable sleeve though |
| Author: | Moe101 [ Mon Mar 25, 2013 5:41 pm ] |
Its a wt sierra ,Well I went through menai and a lot of clay n mud at Appin but if u mean the sleeve thing that has ripples in it I realised that it was torn but I didn't think it was anything so u think that could be a cause |
| Author: | Ace [ Mon Mar 25, 2013 6:07 pm ] |
My small view is the clutch cable sleeve. eg the sleeve that goes over the cable - the 3 odd ft between your gearbox and your left foot. BUT look at it like this, it's a piece of wire sliding in a sleeve, grit or cow shit etc in between anything that would stop it sliding freely will poke it. Pardon my french but you get the idea |
| Author: | Moe101 [ Mon Mar 25, 2013 6:10 pm ] |
Yea lol I get it so my best bet is to replace the cable Ace mate much appreciate the help and time Cheers |
| Author: | Gwagensteve [ Mon Mar 25, 2013 7:52 pm ] |
Sierras aren't known for trashing cables the way vitaras are. Moe, it might be the thrust bearing jamming up because here's watermud/grit in the bell-housing. A new clutch cable won't hurt, but don't be too surprised if it doesn't make the problem go away. If the problem persists once a new cable has gone in, it's time to pull the gearbox and replace the thrust bearing, along with clean/grease the spigot it runs on. Unfortunately running in mud does this sort of thing, along with starters, alternators and seals. Steve. |
| Author: | Moe101 [ Mon Mar 25, 2013 8:59 pm ] |
Yea thanks Steve ill try the cable cause it was pretty crap It was touching the timing belt and ripped it so hopefully nothing major |
| Author: | stockman [ Mon Mar 25, 2013 9:02 pm ] |
I hope you mean alternator belt Check that the outer casing hasn't split where the belt has been rubbing. |
| Author: | Moe101 [ Sun Mar 31, 2013 6:47 am ] |
Fixed the cable worked for 3 hours got me to Stockton and jammed again I think the thrust bearing is goone Despite all odds got me through 2 days of dunes with no clutch lol and had fun climbing hills my mate's hilux turbo diesel couldn't Now I'm stranded with a popped tyre thanks to my brother we slept in the car lol and now the journey home ! A pic of her https://m.facebook.com/?_rdr#!/photo.ph ... =858665157 |
