It is currently Thu Nov 05, 2026 4:22 am
Vehicle: No car YET lol
Post Posted: Mon Mar 25, 2013 2:30 pm
Hey guys just wondering if anyone has Had this problem
My clutch got really hard after two offroad trips it kind of feels like I'm pressing the brakes
I tried adjusting the nut on the cable helped a bit but feels like the car has trouble selecting gears from 1st to second
Any help would be much appreciated cheers
Post Posted: Mon Mar 25, 2013 2:33 pm
Car?............
Vehicle: 86 SJ413 dings / rust / 30's
Post Posted: Mon Mar 25, 2013 2:59 pm
Cable clutch - must be a real zook..... any chance you drove through some muddy water and its got into the sleeve or possibly pooed up the pivot pin on the gear box or maybe in the firewall rubber. My guess is its in the cable sleeve though
Post Posted: Mon Mar 25, 2013 5:41 pm
Its a wt sierra ,Well I went through menai and a lot of clay n mud at Appin but if u mean the sleeve thing that has ripples in it I realised that it was torn but I didn't think it was anything so u think that could be a cause
Post Posted: Mon Mar 25, 2013 6:07 pm
My small view is the clutch cable sleeve. eg the sleeve that goes over the cable - the 3 odd ft between your gearbox and your left foot. BUT look at it like this, it's a piece of wire sliding in a sleeve, grit or cow shit etc in between anything that would stop it sliding freely will poke it. Pardon my french but you get the idea
Post Posted: Mon Mar 25, 2013 6:10 pm
Yea lol I get it so my best bet is to replace the cable
Ace mate much appreciate the help and time
Post Posted: Mon Mar 25, 2013 7:52 pm
Sierras aren't known for trashing cables the way vitaras are.
Moe, it might be the thrust bearing jamming up because here's watermud/grit in the bell-housing. A new clutch cable won't hurt, but don't be too surprised if it doesn't make the problem go away.
If the problem persists once a new cable has gone in, it's time to pull the gearbox and replace the thrust bearing, along with clean/grease the spigot it runs on.
Unfortunately running in mud does this sort of thing, along with starters, alternators and seals.
Post Posted: Mon Mar 25, 2013 8:59 pm
Yea thanks Steve ill try the cable cause it was pretty crap
It was touching the timing belt and ripped it so hopefully nothing major
Vehicle: 4wd
Post Posted: Mon Mar 25, 2013 9:02 pm
I hope you mean alternator belt :lol:
Check that the outer casing hasn't split where the belt has been rubbing.
Watch out or you'll get sued.
Post Posted: Sun Mar 31, 2013 6:47 am
Fixed the cable worked for 3 hours got me to Stockton and jammed again I think the thrust bearing is goone
Despite all odds got me through 2 days of dunes with no clutch lol and had fun climbing hills my mate's hilux turbo diesel couldn't
Now I'm stranded with a popped tyre thanks to my brother we slept in the car lol and now the journey home !
A pic of her
https://m.facebook.com/?_rdr#!/photo.ph ... =858665157
Users browsing this forum: No registered users and 114 guests
