It is currently Tue Nov 03, 2026 1:49 pm
Post Posted: Wed Apr 03, 2013 6:42 pm
thinking about doing a 2" body lift on my 88 sierra and was wondering whether the tcase lift is needed as well? or can you get away without it?
its already got OME 1.75" spring lift (which has sagged heaps!) do i need extended brake lines as well?
Post Posted: Wed Apr 03, 2013 6:46 pm
No, You don't NEED to lift the transfer. But it can't hurt.
Post Posted: Wed Apr 03, 2013 7:07 pm
If you do body lift, lifting the transfer offers two benefits.
It helps with clearance (which helps to protect the transfer).
It helps prevent/reduce the risk of the transfer shifter fouling on the body and going from low range into neutral.
The only real downside, is it will make your drive shafts extend slightly more.
As per extended brake lines, flex it up and see.
If they are stretched etc get some new ones, if they appear fine, they most likely are.
Post Posted: Wed Apr 03, 2013 7:31 pm
cheers guys!
whats the worst that can happen with the drive shafts being extended? are spacers also needed?
Users browsing this forum: No registered users and 18 guests
