| Auto lockers front and back ? http://auszookers.com/forum/viewtopic.php?f=37&t=40112 |
| Author: | bodybordnmd15 [ Sun Apr 07, 2013 9:22 pm ] |
| Post subject: | Auto lockers front and back ? |
If you have an Auto Lokka in the front can you set one hub to 'free' so that you can steer? |
| Author: | 31zook [ Sun Apr 07, 2013 9:30 pm ] |
| Post subject: | Re: auto lokers frunt and back |
Yes. But only to a degree. The locked in wheel will still cause some resistance... |
| Author: | christover1 [ Sun Apr 07, 2013 9:30 pm ] |
I have had a Sierra, and now a Vitara, with auto lockers front and rear for years. I have no problem steering. I had a problem steering when I had a welded front diff. I used to unlock one hub for steering, and only locked it again if 4wd was needed. |
| Author: | SierraDan [ Sun Apr 07, 2013 9:33 pm ] |
I have no troubles steering in the front with an auto locker. |
| Author: | bodybordnmd15 [ Sun Apr 07, 2013 9:43 pm ] |
thanks boys but what about on sand ? |
| Author: | bodybordnmd15 [ Sun Apr 07, 2013 9:46 pm ] |
thanks boys but what about in the sand do you find frunt and back on will dig in more |
| Author: | mnemonix [ Sun Apr 07, 2013 9:58 pm ] |
Likewise. I've got an auto locker in the front with hubs that are permanently locked both on and offroad. Never have an issue with steering. |
| Author: | bodybordnmd15 [ Sun Apr 07, 2013 10:05 pm ] |
yer but when ther bouth on at the same time on the sand |
| Author: | bodybordnmd15 [ Sun Apr 07, 2013 10:15 pm ] |
christover1 wrote: I have had a Sierra, and now a Vitara, with auto lockers front and rear for years. I have no problem steering. I had a problem steering when I had a welded front diff. I used to unlock one hub for steering, and only locked it again if 4wd was needed. haw was that on the sand |
| Author: | christover1 [ Mon Apr 08, 2013 7:06 am ] |
My Vitara towed a camper trailer on sand recently, no problems.
| Author: | SierraDan [ Mon Apr 08, 2013 9:51 am ] |
| Post subject: | Re: Auto lockers front and back ? |
In any and every situation. No problems. |
| Author: | bodybordnmd15 [ Mon Apr 08, 2013 10:52 am ] |
Sweet |
| Author: | bodybordnmd15 [ Mon Apr 08, 2013 10:53 am ] |
SierraDan wrote: In any and every situation. No problems. With frunt and back locked? |
| Author: | sideways [ Mon Apr 08, 2013 10:59 am ] |
Yeah, Sierra dan is locked front and back. |
| Author: | SierraDan [ Mon Apr 08, 2013 11:24 am ] |
bodybordnmd15 wrote: SierraDan wrote: In any and every situation. No problems. With front and back locked? Yes. Lockright Auto lockers front and rear. Steering is heavy under power on the rocks. Come off the accelerator a little bit and it frees up for normal turning. Thats the worst of it. |
| Author: | bodybordnmd15 [ Mon Apr 08, 2013 7:25 pm ] |
ok sweet thanks boys |
| Author: | Built4thrashing [ Mon Apr 08, 2013 8:39 pm ] |
I think you just need to man up. Auto lockers will disengage on when you back off the power |
| Author: | sideways [ Mon Apr 08, 2013 10:10 pm ] |
He already has a spartan in the rear diff, he just wasn't sure how a front one would effect it. |
| Author: | suzukikid [ Tue Apr 09, 2013 5:53 pm ] |
I got lock rites front and rear on 34s and don't struggle! Don't get me wrong sometimes it's hard but it's ok! I have had power steering set up in the shed for a year now... And undecided if I will use it or not! |
