It is currently Thu Nov 05, 2026 11:30 am
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Apr 08, 2013 1:09 pm
Hi
Does anyone know of a bracket or mounting system that will allow an arb bullbar to be fitted normaly to a bodylifted Jimny?
Can the bolts that atach the bullbar to the mounting kit be moved to reposition the bar without affecting the crumple zone and airbag compliance?
cheers
Post Posted: Mon Apr 08, 2013 7:09 pm
Re-drill the top two holes lower to suit you body lift. The bottom one drill once its all mounted up again.
Post Posted: Sun Apr 21, 2013 9:05 pm
Great success lifting the bar to suit bl today pompoms
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Apr 23, 2013 8:09 am
Thanks Joeblow.
Redrilled the all three and put in a larger 1/2 inch bolt, as the origional bolts from the bottom of the bar (see first post) were stuffed.
the arb insilation ( old holes up top) left the bar a bit loose. these 3 new holes are spot on with almost no play.
previously courrigations have caused the bar to shift and damage the plastic flairs.
to lift the bar the 50 mill the following had to be removed from the bullbar mounting brackets (left) and the bottom of the bullbar (right)
in the top photo you can see where i cut across.
looks nice and tidy now, with a better fit than before.
Users browsing this forum: No registered users and 10 guests
