It is currently Fri Nov 13, 2026 4:53 pm
Vehicle: 98 Coily
Post Posted: Wed Apr 17, 2013 9:12 pm
Was driving down the road a bit ago and the engine all of a sudden became sluggish and wanted it die until I pushed the clutch pedal in. Idles fine and starts fine, just dies when I let the clutch out in gear... Any ideas?
Engine seems to rev fine in neutral or in gear with the clutch pedal depressed. As soon as I attempt either forward or reverse the engine dies.
Post Posted: Thu Apr 18, 2013 7:34 am
When you let the clutch out, is it stalling due to something seized in the driveline or does it just splutter and stop?
Can you push the car forwards/backwards?
Vehicle: 85 ' Drover
Post Posted: Thu Apr 18, 2013 7:39 am
Does the sierra ignition system have a condensor?
Post Posted: Thu Apr 18, 2013 8:26 am
Only in 1.0's.
1.3's are all electronic as are all 1.6's.
Vehicle: 98 Coily
Post Posted: Thu Apr 18, 2013 9:00 am
I can push the car and had to tow it home. As I push the gas (even revving the engine higher than I normally would) and let out the clutch the engine just revs down and dies completely when the clutch is released completely (my foot is on the gas the whole time)
Post Posted: Thu Apr 18, 2013 9:39 am
If you put the car in gear (EG:1st) and try to start it with clutch out what happens?
I'm thinking it's possibly something like a seized gearbox.
Something else worth looking at is wiring in or around the pedal assembly.
If someone has run a wire where it can get pinched there could be allsorts of dramas.
Vehicle: 98 Coily
Post Posted: Thu Apr 18, 2013 9:56 am
Ok. Seems that the problem is not related to the clutch pedal/driveline. I started in neutral, didn't touch the clutch, then revved the engine and it stalled out just as it did before. Guessing fuel system? It has started running really rough in the last day or so.
Have a cheapo fuel filter in there now while waiting for one I ordered.
I'll take a look around the pedal assembly just in case as I had to fix the clutch pedal not so long ago.
Vehicle: Sj413k,35" silverstones
Post Posted: Thu Apr 18, 2013 4:00 pm
Mine did that a while ago. Turns out I had something blocking the feed line. Take ya fuel cap off and then take ya fuel line off at the carby, blow from the carby with compressed air. Worked a treat for me..
Vehicle: 98 Coily
Post Posted: Thu Apr 18, 2013 6:25 pm
I'll give that a go, hopefully it is something silly like that... was worried when want33s started talking about a seized gearbox.
Post Posted: Fri Apr 19, 2013 9:58 am
My guess is fuel pump. Exact same symptoms as what you describe. Pull the inlet to the carby and see if you are getting sufficient flow, it should fairly pulse out of there so have something to catch it when you turn the car over.
Vehicle: 98 Coily
Post Posted: Fri Apr 19, 2013 11:20 am
Not sure what this part is called... but it doesn't look right to me.
http://i1356.photobucket.com/albums/q73 ... dbbbb9.jpg
http://i1356.photobucket.com/albums/q73 ... 62c48b.jpg
I tried the compressed air trick and it seemed to work a bit. I'm gonna clean out the fuel system and hopefully that will fix my problem. Does the carb kit from suzistore (http://www.suzistore.com.au/onlinestore ... etail.html) come with everything I will need to fix the carb up?
Thanks
Vehicle: 98 Coily
Post Posted: Fri Apr 19, 2013 11:25 am
I'll give that a go next... Thanks
Post Posted: Fri Apr 19, 2013 12:53 pm
Get a carby kit. Yes that one from suzisport has the lot. The pictures you took were of the accelerator pump
Vehicle: 98 Coily
Post Posted: Mon Apr 22, 2013 9:38 pm
Cleaned out the carby and the tank, new fuel filter and she's good to go...
Users browsing this forum: No registered users and 32 guests
