It is currently Sat Nov 14, 2026 3:04 pm
Vehicle: tin top sj70
Post Posted: Mon May 06, 2013 6:27 pm
Hey all I've notice backlash through the input of my 6.5 transfer case. Should I be worried ?
Post Posted: Mon May 06, 2013 6:39 pm
How much backlash?
There will always be some backlash, but depends how much.
How many kms on the gears?
Post Posted: Mon May 06, 2013 6:45 pm
5mm or something. Ill have a look later.
I dont know how many. I've put 5000ks on them back I bought the transfer second hand for a good price
Post Posted: Mon May 06, 2013 6:47 pm
Lock up the output.
At 90 degrees place a ruler on one of the flange yolk/drive flange bolts, and measure how far it will go.
Try it in high and low.
Ill go measure a stocky and get back to you (ill maybe do the other when i wont mind getting dirty).
Post Posted: Mon May 06, 2013 6:48 pm
5mm sounds about right. Certainly nothing to be concerned about.
Post Posted: Mon May 06, 2013 6:55 pm
On the outside of the flange, rough measurements in poor light.
Ill chuck a dial indicator on two stockies when I get the chance.
I got 2mm backlash in high, and 3-4 mm backlash in low
Post Posted: Mon May 06, 2013 7:09 pm
Most of it will be in the dog teeth on the shift ring, backlash between gears is most likely perfect.
Post Posted: Mon May 06, 2013 7:13 pm
Yeah it roughly four to five in high and low
Post Posted: Mon May 06, 2013 7:26 pm
Backlash due to dog teeth in shift ring should be same stock vs aftermarket.
So any difference would be in the gears etc.
A stock case should have a smidge more than desired for stock gears, as it has wear and tear on counter and thrust washers etc
Is it whiney?
Does it slap a bit when you accelerate or engine brake?
Post Posted: Mon May 06, 2013 7:28 pm
Yeah it is whiney and slaps when I accelerate and engine brake.
Post Posted: Mon May 06, 2013 7:29 pm
Mine started doing that before it ate itself on the highway
I would be inclined to open it up. Will cost you nothing to check.
Check the thrust washers, counter shaft and inside the counter (take pics please)
Can get a new counter shaft and needle bearings from trail tough for $45 If needed.
Also possibly shim if needed (if it wasnt done on assembly).
Post Posted: Mon May 06, 2013 7:33 pm
What sort of damange\ wearing am i looking for
Post Posted: Mon May 06, 2013 7:38 pm
The thrust washers will be worn, but depends to what degree.
That's the counter shaft, and failed input gear on mine.
No pics of needle bearings, if theres any signs of pitting etc, replace them.
Inside the counter gear, it can wear too.
Its possible it was assembled without the correct shims etc too...
Id love to know more info on this...
http://auszookers.com/forum/viewtopic.php?f=5&t=40562
Post Posted: Mon May 06, 2013 7:42 pm
I'm a little worried about the shimming. Don't have a clue what im doing
Post Posted: Mon May 06, 2013 7:51 pm
Read the gear install guide on low range.
It tells you how assemble it and shim it etc.
You are just doing the reverse, and checking the wear and tear components.
then follow the guide to reassemble and check shims.
Post Posted: Mon May 06, 2013 8:04 pm
I might give it a good
Post Posted: Tue May 07, 2013 4:04 am
If you tear it down, and Im wrong...
you will swear at me..
put it back together and swear at me some more.
Maybe abuse me a bit more, problem over. we all learn a bit...
If you don't tear it down, and your case goes bang ...
Id much prefer I'm wrong and you're pissed at me, than you wrecking your gears.
Post Posted: Tue May 07, 2013 5:55 am
Why would I get pissed, I dont care. Might even learn something on the way.
Post Posted: Tue May 07, 2013 6:41 am
Somewhat near worse case scenario..
If I pulled my xfer apart on someone elses advice, and it didnt need to be done.
Id probably swear and be annoyed.
