It is currently Sat Nov 14, 2026 9:30 pm
Vehicle: Suzuki Sierra '90 Wide Track
Post Posted: Tue May 14, 2013 3:00 pm
Hey guys I have a g13a out of a barina to go into my zook. Will the carby off the 1.3 swift fit onto it?
Sent from my GT-I9300 using Tapatalk 2
Post Posted: Tue May 14, 2013 4:00 pm
Barina and Swift are same so YES a Swift carby will fit a Barina motor.
Post Posted: Tue May 14, 2013 5:25 pm
Awesome. Just wanting to check. Cheers
Vehicle: Coil Sierra
Post Posted: Tue May 14, 2013 9:01 pm
Let us know how you go as a suzuki shop told me their a different carby to the sierra.
Post Posted: Tue May 14, 2013 9:23 pm
That is correct.
Barina/Swift carby is different to Sierra. It has a lot more pollution gear on it. Cable setup is different. Air hat is different. Not sure about the mounting bolts.
The OP's question isn't too clear.
Post Posted: Wed May 15, 2013 7:52 am
What more do you need to know? I have a G13a motor and I can purchase a carby from a g13ba swift. I was told there is more bits that dont need to be connected but apprently should still work?
Post Posted: Wed May 15, 2013 10:19 am
What is the G13a motor going in? If it's the sierra that you have in your profile than you won't want a swift carby. They are overly complicated and have a heap of pollution gear on it. The inlet manifold is different and possibly the mounting bolts as want33s has said. If it's going in a swift or barina than use it, if it's going in a sierra get a sierra carby and inlet manifold.
Post Posted: Wed May 15, 2013 1:29 pm
Its going in my zook but it is a motor from a Barina apparently. I got the inlet manifold from the same person selling the carby so I am assuming it should all bolt togethet.
Post Posted: Wed May 15, 2013 1:42 pm
Don't waste your time trying to fit a Swift/Barina carby to a Sierra manifold or trying to make a FWD manifold work in a RWD car.
Post Posted: Thu May 16, 2013 2:11 am
The FWD intake has the water outlet on the left side if fitted in the original east-west configuration, which translates to the rear of the engine in a north-south installation, the RWD intake has it at the front.
Post Posted: Thu May 16, 2013 7:20 am
Turns out I was wrong. The manifold I have is a Sierra one. Cheers guys.
Users browsing this forum: No registered users and 26 guests
