| Author |
Message |
gregwatkins75
Joined: Mon Oct 25, 2010 12:13 pm Posts: 1334 Location: WeSt RaDeLaIdE
Vehicle: Suzukiless these days..
 Posted: Sat May 11, 2013 8:33 pm |
Got what looks to be a rather heavy oil leak.....under the GV seems to be spraying out from rear of motor that has only done 100000kms v6 2.5lt in a 2001 model... is it common for these to do rear main seals or should I start looking at other areas first? Strange thing is it only seems to have started after oil change? swapped oil to 5-30 full synthetic penrite oil.. and yes the new oil filter is on and done up correctly... any suggestions?
Joined: Sat Aug 12, 2006 11:30 pm Posts: 6456 Location: Radelaide ofcourse!
 Posted: Sat May 11, 2013 8:49 pm |
Is it definitely from the centre not, not from the side?
_________________ Chop
gregwatkins75
 Posted: Sat May 11, 2013 8:51 pm |
Not sure cleaned it fully today, checking after a drive tomorrow,,, possibly from passenger side as it is spraying back to exhaust .... seems to be under. pressure where ever its coming from as its sprayed everywhere...
 Posted: Sat May 11, 2013 9:00 pm |
I know the first time I dropped the oil on the gv, the shit went everywhere as its a prick to get to. And I thought I had a huge leak also, especially after reading that someone mentioned the rubber from the original filter stayed in position when they put a new one on meaning it leaked badly. Mine was just leftover oil on the cross member, even though I thought I had degreased it well.
I'm thinking one of those k&n jobbies will be going on next.
atari4x4
 Posted: Sat May 11, 2013 9:08 pm |
rear main
gregwatkins75
 Posted: Sat May 11, 2013 9:13 pm |
Im sure its leaking chop as its very clean oil......
Hopping its not the rear main Gus.....just paid the years council rates and school fees, and months home loan.......might have to register the white one for a while..!
shabz
Joined: Sun May 03, 2009 11:30 pm Posts: 646 Location: Melbourne
 Posted: Sat May 11, 2013 11:56 pm |
atari4x4 wrote: rear main  Agreed. Happened to mine at about the same kays...oil spraying everywhere including on the back door!
gregwatkins75
 Posted: Sun May 12, 2013 8:24 am |
Yer thats what I was dreading....What was your repair cost Shabz...or did y ou do it yourself!
shabz
 Posted: Mon May 13, 2013 9:47 pm |
At the time i was getting quotes of about 1100-1500, and most of that was labour....so i did it myself. Haven't had an issue since viewtopic.php?f=5&t=19502
gregwatkins75
 Posted: Mon May 13, 2013 11:01 pm |
Thinking of having a crack myself.... did the swb 1.6 lt rear main seal and clutch in the drive way by myself.... with no experience and its still going.....never pulled out a auto gearbox though.....any tips ?
elky
Joined: Sat Aug 07, 2010 1:15 am Posts: 74 Location: sunny cst
 Posted: Sun May 19, 2013 12:49 pm |
i havent done a vit but i assume it is similar to most cars pretty much the same as taking out a manual BUT you gotta access the back of the flexplate and undo the bolts holding the t/convertor on, so when you slide the box off the motor the convertor goes with the box, you can cheat and leave the convertor on but it gets messy and the convertor still needs to come off and be fitted to the box before refitting anyway
you will also have to disconnect cooler lines and shifter linkage
dunno about any other vit specific things like crossmembers and other bits to get in the way
cheers
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Sun May 19, 2013 1:15 pm |
Make sure 100% that it is rear main before digging in! It's really annoying when you get the box out and find that the oil was coming from up above and just trickling down thru the bellhousing.
gregwatkins75
 Posted: Sun May 19, 2013 2:01 pm |
Scrawn where above exactly are you talking about?
going to go up to a 10/40w synthetic....see if that stops it leaking before i pull the box first....
fordem
Joined: Mon Apr 19, 2010 11:30 pm Posts: 2656 Location: Georgetown, Guyana
 Posted: Mon May 20, 2013 1:31 am |
Cam position sensor O ring.
