It is currently Thu Oct 01, 2026 6:14 pm
Post Posted: Tue Jun 04, 2013 7:43 pm
I have a question..
I have Air Operated auto locking hubs...
If the worse should happen and the transfer wont disengage...
What would happen if I disconnected the airline on the pump on the front of the vehicle ?
How would I unlock the system in order to avoid getting diff wind up ?
Post Posted: Tue Jun 04, 2013 7:50 pm
Put the transfer in 2wd.
Post Posted: Tue Jun 04, 2013 7:54 pm
Assuming the Transfer wont move out of 4H or 4L
Post Posted: Tue Jun 04, 2013 7:57 pm
you have drive flanges, no auto free wheeling hubs on a GV the FWH action is in the diff centre
Post Posted: Tue Jun 04, 2013 8:07 pm
Then slowly reverse and try and pop it into 2wd, if that doesn't work then jack a tyre up off the ground and it will then slip into 2wd pinch off piss. Jacking up a tyre releases the windup.
Post Posted: Tue Jun 04, 2013 8:08 pm
OK... So disconnecting the pump would disengage drive to the front wheels ?
Just getting the basics of worse case scenario because I am heading off road next weekend and IF something goes wrong.. I would like to be able to make it back...
Post Posted: Tue Jun 04, 2013 8:13 pm
you worry too much, sure you're not female?
I like to be prepared instead of getting out there and running into something I have no Idea how to rectify
Post Posted: Tue Jun 04, 2013 10:03 pm
When you shift into 4h or 4l, the air pump engages the front diff giving drive to the front wheels.
The front wheels are permanently connected to the driveshafts and into the diff (due to not having free wheeling hubs).
If you were to just unplug the air pump while in 4h or 4l, there will be no drive to the wheels, however the front prop shaft and transfer will still be spinning, and i don't imagine that'll be a good thing with no load. (could be wrong?)
If you have trouble getting back into 2wd try what shep suggested and you'll be fine
Users browsing this forum: No registered users and 38 guests
