It is currently Mon Sep 28, 2026 9:53 pm
Vehicle: 98 Jimny
Post Posted: Wed Jun 12, 2013 11:12 am
hi i was wondering when ever i flex a tiny bit or alot the car jimny makes a really loud cracking noise like my springs or shocks have snapped but they are brand new just 500km on them.
does anyone know what it could be or what i could check to see if they are broken??
Post Posted: Wed Jun 12, 2013 11:18 am
it may be just the springs loading and unloading in their lands
springs catching on the springs seat, rotate the spring 10mm away from the recess on the spring seat.
have a search there should be some pics floating around.
Vehicle: 98 Jimny
Post Posted: Wed Jun 12, 2013 11:21 am
soo is this bad??
Post Posted: Wed Jun 12, 2013 11:22 am
no, it's a simple instillation error.
Vehicle: 98 Jimny
Post Posted: Wed Jun 12, 2013 11:27 am
well it got its 500km check up yesterday and they said its fine but i think they are bull shitting me because it sounds like something it like completely snapping each time i flex even when i go into my drive way which is like a 5cm gutter. ok thanks ill look around again :)
Post Posted: Wed Jun 12, 2013 11:39 am
My Vitara was doing that, took ages to find it. It was loose body mounts on the rear end.
I was lookin at springs etc, too.
Post Posted: Wed Jun 12, 2013 11:45 am
on the 500km check up they would have just checked for loose bolts etc, it's quite common for jimny's to make this exact same noise.
Vehicle: 03 Jimny
Post Posted: Wed Jun 12, 2013 11:55 am
Nothing to be worried about, my jimny and alot of other jimnys I know of do the same thing.
Vehicle: 2008 Jimny Standard As :-)
Post Posted: Wed Jun 12, 2013 2:23 pm
Mine does too
Post Posted: Wed Jun 12, 2013 3:02 pm
none of your jimnys would make this noise if you took ataris advice and fixed it. takes about 30 minutes and two or three beers :cheers:
Post Posted: Wed Jun 12, 2013 3:05 pm
I will be now I know the cause :wink:
Vehicle: Jimny 99 2" lift, 31s etc
Post Posted: Wed Jun 12, 2013 3:21 pm
Sway bar?
Post Posted: Wed Jun 12, 2013 4:14 pm
:roll:
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Jun 13, 2013 7:20 am
i gave up on fixing it and just got used to the noise, the springs do just move around in their seat. every time i go out my rear left will rotate up to a 1/4 turn back to being noisy.
i find if i rotate it hard up in the seat its actually quieter longer.
Vehicle: Coil Sierra
Post Posted: Thu Jun 13, 2013 1:28 pm
Also makes that noise when the trailing arm bolts are loose.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Jun 14, 2013 8:03 am
good to know, mine have a history of sheering off. 3rd bolt in the same place now. unless i got a bad batch of locktite. might look into that
