http://auszookers.com/forum/
High revving problem KILLING ME!!!
http://auszookers.com/forum/viewtopic.php?f=37&t=41420
Author:  Greeno [ Fri Jun 14, 2013 8:40 pm ]
Post subject:  High revving problem KILLING ME!!!
Ok, sierra starts good, idles good, goes good. But when warm it can sometimes just decide to rev up to just over 2000 rpm, OR when at night it will idle normal then when i turn the lights on it revs up to the same again. ONLY WHEN THE LIGHTS ARE ON!!! WTF!!! Its tearing me apart.
Please someone have a clue of whats going on here? I would have thought the lights would not be connected to anything that could affect the rpm's of the vehicle?
On a side note, also when i turn the lights on the sub woofer turns off aswell, only the subwoofer. Stupid electrics. Darn it!!
Author:  atari4x4 [ Fri Jun 14, 2013 8:51 pm ]
Post subject:  Re: High revving problem KILLING ME!!!
search for idle up solenoid, HEAP of info hidden under the button up the top. :wink:
Author:  Greeno [ Fri Jun 14, 2013 9:37 pm ]
Thanks Atari I have been trying search for about a week google and all but not much comes up when you dont know what things are called. So its definitely that now that i turn the lights on and watch it shift out.
But why so much? it sits around 2200rpm when warmed up. and that aint fun trying to do slow stuff like trying to go to supermarket carpark at night hahaa! Ill search around for tuning? or something like that.
Thanks again
Author:  atari4x4 [ Fri Jun 14, 2013 9:51 pm ]
Search term used: idle up solenoid = search.php?keywords=idle+up+solenoid&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
happy reading.
Author:  Daves4wd [ Sat Jun 15, 2013 8:38 am ]
Mine was doing this but was coming and going found out that the accelerater cable was getting stuck in the casing near the pedel some inox in it and she like new hahaha
Author:  coily96 [ Sun Jun 16, 2013 7:00 pm ]
Front of carby, get someone to turn lights on and you will see the idle up thingy move the accelerator arm. Back the screw off with lights on to required rpm. Back right off if you dont want it playing up again.
Author:  Greeno [ Wed Jun 19, 2013 11:13 pm ]
Found this, screw is backed right off not touching the arm at all, no difference. Unscrewed the allen key screw that the little arm pushes against also while the lights were on and it wasnt even touching the arm so something else was making the accelerator arm move..... Thats why I am so confused!
There was another bit that looked like the part that was in your own thread about this issue but its on the passenger side of the carby and has no screws or anything near it for adjustment......
Author:  jono165 [ Thu Jun 20, 2013 6:33 am ]
If you have ruled out the idle up solenoid there a couple of other things it could be.
Do the 2 coolant hoses at the back of the carby get hot? If they arent then the choke won't come off at temperature.
Could also be blocked jets inside the carby
My carby acts a bit strange too its been rebuilt once and I've opened it up and cleaned it out again on a separate occasion, I've also put an extra filter at the fuel inlet on the carby.
Author:  Greeno [ Fri Jun 21, 2013 8:21 pm ]
Carby works fine its something electrical, theres another little solenoid looking thing on the passenger side of the carby. Not sure what that does....
Stooopit electrics!
Author:  jono165 [ Fri Jun 21, 2013 8:25 pm ]
The one of the passenger side is the fuel cut solenoid.
Author:  alien [ Sat Jun 22, 2013 12:56 am ]
sounds like a buggered choke to me... does it backfire on engine braking?
oh wait, just read the lights thing... ummmmm
Author:  Greeno [ Sat Jun 22, 2013 3:24 pm ]
I trhought it would be choke aswell but that has nothing to do with electrics does it?
Author:  Greeno [ Sat Jun 22, 2013 3:31 pm ]
Well it can bloody well stop cutting fuel when im halfway on my side up some obstacle haha, jk. Damn carby
