It is currently Tue Aug 04, 2026 2:51 am
Vehicle: Coil Sierra
Post Posted: Fri Aug 23, 2013 9:35 pm
The 1L case has two single wires with a terminal on each
The coily has a round plug. To get the light to work on the dash is it just the case of cutting the plug off the coily case and wiring it to the 1L case.
Will polarity cause a short?
Also i ordered a new bush for the selector, went to install it and there wasnt a bush inside the 1L case. It has a cone shaped spring and the peice that locks the selector stick into place.
Also :? Will the coily speedo cable swap straight over?
Vehicle: Tin Top
Post Posted: Mon Aug 26, 2013 5:46 pm
Coily speedo cable bolts straight in and so will your Coily 4wd switch so you don't need to rewire anything..
Post Posted: Mon Aug 26, 2013 6:57 pm
Im missing the plug on the 1L end. Speedo cable went straight in thankyou.
Users browsing this forum: No registered users and 59 guests
