http://auszookers.com/forum/
Sierra coily axle innards
http://auszookers.com/forum/viewtopic.php?f=37&t=42664
Author:  stem1 [ Tue Aug 27, 2013 4:39 pm ]
Post subject:  Sierra coily axle innards
Hi all, does the Sierra coily front axle share the diff centre, axle shafts, CVs and stubs with the other Sierra's or the Jimnys?
Ditto for the rears.
Are all Sierra coilys WT?
Is there an issue with getting spares for the S coily? Which parts?
Thanks
Author:  tanshi [ Tue Aug 27, 2013 4:45 pm ]
Post subject:  Re: Sierra coily axle innards
front, no, no, no and no, nothing is the same in the front axle
rears pretty much nothing. only the rear diff carrier is similar.
coilys are actually wider track than wide track, so technically no
yes, because coilys are less common they can be hard to find all parts for
Author:  stem1 [ Tue Aug 27, 2013 9:41 pm ]
OK, that chops that idea neatly, thank you! I'm gathering from other threads that all Sierras after mid 88ish are WT, is that correct?
Thanks
Author:  Marko_SJ [ Tue Aug 27, 2013 10:00 pm ]
Thanks
Yes, except for Indian built marutis, which can be WT, but most are Narrow Track.
If you're buying a sierra definitely get a leafy IMHO. LWB 1.3 litre narrow track is best. I wish I didn't sell mine, it could have rode so much better(needed to de rate springs) and looked awesome and handled better off road.
Author:  stem1 [ Tue Aug 27, 2013 10:06 pm ]
Handle better off road, that's interesting, I would have thought the SWB to be an advantage. In what way is the LWB better?
Author:  Marko_SJ [ Tue Aug 27, 2013 10:30 pm ]
Having more wheelbase makes it feel 'safer' going up and down things. It also allows you go get "over" things with the front wheels when the back wheels are on the straight and level (on really really steep stuff -that I can't/won't drive- a SWB can flip ). Then instead of being vertical you are on less of an angle.
Basically, they are more stable in general which is a really good thing in a 4x4. Although SWB is great for ducking through trees and tight sections, where everyone else is trying to do 3 point turns and getting bogged in mud.
The steering is much more responsive in the SWB, even though it was the same steering box.
Some people here can explain it way more technically than me.
Author:  pezz [ Tue Aug 27, 2013 10:33 pm ]
lwb and swb both have their pro's and con's
but lwb sierra's are cool as fook ;)
Author:  tanshi [ Wed Aug 28, 2013 7:53 am ]
Depends what you want to drive
