http://auszookers.com/forum/
Removing Stud from Drum
http://auszookers.com/forum/viewtopic.php?f=37&t=42785
Author:  matth27 [ Tue Sep 03, 2013 8:03 pm ]
Post subject:  Removing Stud from Drum
Trying to remove my rear drums and one of the splines is stripped and the stud just keeps spinning.
Any ideas on how to undo it?
Author:  pezz [ Tue Sep 03, 2013 8:07 pm ]
Post subject:  Re: Removing Stud from Drum
cold chisel is one option
Author:  buzbox [ Tue Sep 03, 2013 8:29 pm ]
Hit with a hammer to remove the stud, and replace it
Author:  pezz [ Tue Sep 03, 2013 8:31 pm ]
think he means the nut is still on the stud
Author:  jono165 [ Tue Sep 03, 2013 8:42 pm ]
I'd just cut the nut off and replace the stud. If the hole in the axles is stuffed from the stud spinning i'd just source a 2nd hand axle.
Author:  buzbox [ Wed Sep 04, 2013 6:59 am ]
Well that's a bit more of a complex operation then.
Angle grinder to chop it off.... Then hammer ;)
Author:  cairns27 [ Wed Sep 04, 2013 7:15 pm ]
More complex that what?
bye
Author:  atari4x4 [ Wed Sep 04, 2013 7:24 pm ]
Hi
:? what bit don't you get?
pretty sure he means it's not as simple as knocking out the old stud as mentioned in an earlier post of his & if the nut is still on & it's spinning the knurled section on the stud or the wheel nut is stripped it will need to be cut off.
Bye
Author:  buzbox [ Thu Sep 05, 2013 12:54 am ]
An explanation of an explanation, now that's deep.
Thanks Atari , your like a miniature Buddha ;)
