It is currently Tue Aug 04, 2026 2:51 am
Vehicle: 89 Sierra Widetrack
Post Posted: Tue Sep 10, 2013 4:23 pm
Hey Gents,
Had a look around and did some searches but I seem to find more info just on the flanges. Just in the process of doing a g16B swap using one from a Baleno and just thinking about the exhaust. I found these extractors on eBay but they note its for a sierra with a Vitara G16B I assume they would be similar bit would they suit a Baleno G16B? Link below
http://bit.ly/13DDShK
Cheers,
Azza
Post Posted: Tue Sep 10, 2013 4:25 pm
they're essentially the same motor apart from the baleno intake differs, pretty sure they are the ones that everyone uses for G16b powered sierra's.
Post Posted: Tue Sep 10, 2013 4:57 pm
Sweet. Thanks for the quick reply.
Payday this Friday so i will be buying this and a new set of body mounts
Azza
Vehicle: Coil Sierra
Post Posted: Wed Sep 11, 2013 8:29 pm
MPH are quick with postage and ive had my set for a few years and had no problems.
Vehicle: 92 tintop sierra
Post Posted: Thu Sep 12, 2013 8:57 pm
I had issues with them. Ended up buying some off low range. Heaps better.
Post Posted: Thu Sep 12, 2013 9:08 pm
in MPH's defence, you seem to have issues with everything... brake lines, PS brackets, headers, steering arms, etc, etc.
Post Posted: Fri Sep 27, 2013 10:46 am
Got the extractors yesterday and they are well made for $200
Vehicle: 4wd
Post Posted: Fri Sep 27, 2013 10:58 am
I had a set from Rod too.
I asked for a custom setup comprising of Sierra extractors on a Vitara flange with a o2 bung. (well before he offered them as a set)
Was really disappointed with what I got. The flange was roughly cut, the pipes themselves wanted to sit 10mm into my engine mount and the whole thing seemed very freehand.
I hope now that he is offering this as a complete unit he has a jig setup and is pumping out quality not kwality.
Watch out or you'll get sued.
Post Posted: Fri Sep 27, 2013 11:24 am
I have used wildcat and lukey extractors without a problem. A tiny but of engine mount flange grinding on the removable bracket that sits in the chassis.
Post Posted: Fri Sep 27, 2013 12:53 pm
Hi guys,
Sorry to hear stockman. Photos below of the current flanges. Only have to grind a couple of mm off the bent engine mount
