It is currently Mon Aug 03, 2026 11:26 pm
Vehicle: 92 wt soft top sierra
Post Posted: Wed Sep 25, 2013 5:23 pm
Hi everyone I was just reading some threads and now I am not sure about what to buy I am going to run 31" tyres and 4.9:1 transfer case gears and so what do you guys recommend to buy and funds are not the issue. I am wondering in terms of clutch slippage and long life and how the clutch cable will handle the hd clutch thanks for your help
Vehicle: SJ80, SE416
Post Posted: Wed Sep 25, 2013 5:31 pm
A Sierra doesn't need a HD clutch. A Sierra with reduction gears needs one even less. A Sierra with reduction gears and a driver with mechanical sympathy doesn't need one at all.
Also - old clutch cables die eventually regardless of whether fitting a HD clutch or not so best to get a new cable when replacing the clutch.
Post Posted: Wed Sep 25, 2013 5:42 pm
/\ Exactly.
Post Posted: Wed Sep 25, 2013 5:54 pm
^exactly exactly.
Post Posted: Wed Sep 25, 2013 6:11 pm
Thanks heaps for clearing that up for me I think I might stick to a normal clutch and while I am thinking about it do I need offset rims to run 31s on a 2" lift and 2" body lift
Post Posted: Wed Sep 25, 2013 6:22 pm
31's on a Sierra? I know this is the noob section but have you tried search.php
Post Posted: Wed Sep 25, 2013 9:27 pm
No sorry I haven't but will know
Post Posted: Thu Sep 26, 2013 6:24 am
NPC clutches claim that they can build a HD Exedy clutch with 25% more clamping force with little extra pedal pressure. I have to agree with this.
With stock gearing and 29's, my clutch would stink after anything more than a mild take off through the gears. The exedy smells only under extreme punishment.
I am very happy with it and happy I went this way.
2009 Jimny
Vehicle: 95 Vitara Hardtop
Post Posted: Sun Sep 29, 2013 8:11 am
I replaced my standard clutch in my Vit (and rear main seal) at about 185xxxkm when I was getting gearbox rebuilt. Not sure if it was original clutch but hardly worn at all. Put a standard Exedy in and it works good so far.
Users browsing this forum: No registered users and 55 guests
