It is currently Sun Aug 02, 2026 6:11 pm
Vehicle: 93 LWB Vitara
Post Posted: Fri Nov 15, 2013 9:06 pm
LWB Vitara body wont lift far enough off the chassis. Bumpers off, 1 side of body block nuts and bolt off and the other side loosened off heaps. Cant see where the brake lines need to be altered as it doesnt come through the inner guard on the drivers side? :S Its a just_cruizin kit but i purchased it second hand so no instructions...
Post Posted: Sat Nov 16, 2013 4:39 am
If you ask Greg nicely in a PM he might send you a copy of the instructions and then all will be fixed :wink:
Post Posted: Sat Nov 16, 2013 6:52 am
Brake line comes though the guard on the passenger side, so there's a tip for starters.
I know it's a "thing," but I don't understand only taking bolts out of one side. It's going to twist the mounting studs like a mofo and make getting the second side in much harder.
Post Posted: Sat Nov 16, 2013 8:04 am
Thanks guys, i have the drivers side up first so that shouldnt be a problem. Ill try pulling the nuts right off on the other side and maybe try and jack the other side a little bit too? Those instructions would be amazing!
Thanks
Users browsing this forum: No registered users and 98 guests
