It is currently Wed Oct 07, 2026 8:01 am
Post Posted: Fri Dec 13, 2013 6:34 pm
Hey guys my g16b just started playing up, not idling correctly and in 1st an 2nd when putting your foot down the car sounds lumpy and is lacking power, it goes away as it goes into the end of 3rd, 4th and 5th.
Any ideas?
Also have just done the 110amp alt upgrade not long ago, could this also be apart of the cause?
Vehicle: 89 Sierra Widetrack
Post Posted: Sat Dec 14, 2013 6:56 am
Have you ever cleaned your injectors? I have had injectors give me similar problems.
Also maybe check your fuel filter
Post Posted: Sat Dec 14, 2013 7:49 am
Injectors were serviced 2000kms ago and fuel filter was replaced at the same time,
The conversion was done to my sierra 2000kms ago
Post Posted: Sat Dec 14, 2013 8:02 am
Air flow meter? May just need a clean
Vehicle: SWB Sierra
Post Posted: Sat Dec 14, 2013 9:00 am
Pulled the codes?
Post Posted: Sun Dec 15, 2013 6:36 am
There is no set pattern of things to do here so check everything over
Did it start when you did the alternator? did you disturb any intake hoses? go around and make sure they are all on and tight, an intake leak will do exactly what you are saying
Post Posted: Mon Dec 16, 2013 3:29 am
I would check the crank keyway, you get those symptoms when its trashed. It could be a lot of things but its still worth checking that's torqued properly.
Vehicle: 85 ' Drover
Post Posted: Mon Dec 16, 2013 9:35 am
I reckon ignition timing or camshaft timing.
Check them both.
Post Posted: Mon Dec 16, 2013 6:47 pm
Pulled off the air intake sensor an put it bak on and looks like it has done the trick, cheers for the help guys
Post Posted: Wed Dec 18, 2013 7:06 pm
sounds like an ignition miss under load
Users browsing this forum: No registered users and 74 guests
