It is currently Mon Aug 03, 2026 8:47 pm
Vehicle: 2003 Jimny
Post Posted: Tue Jan 07, 2014 8:54 am
Hi guys,
Looking at converting our 1.3L sierra to a G16B and wondering if there is much difference in terms of performance between a Baleno and Vitara G16B? Any difference in HP, torque etc.
I've read that the Vit conversion is a little easier but I've found a Baleno engine and we already have a bit of experience with engine conversions so hopefully should be able to handle it :?
Would greatly appreciate any advice as don't want to install a Baleno engine if the Vitara engine performs better.
Post Posted: Tue Jan 07, 2014 6:45 pm
Vit and Baleno are almost identical , power wise.
Inlet manifold and air intake/filterbox is the biggest difference.
If I were to do it again I'd prob use Baleno as I think the inlet is neater.
Post Posted: Wed Jan 08, 2014 7:12 pm
you can actually buy a hose that will connect a baleno throttle body directly to a sierra airbox . ive got a pic with it on a gti engine but the baleno is the same deal . it wasnt actually connected to the throttle body in this pic because i had a sr20 throttle body fitted which is much larger than the standard gti or baleno throttle body.
Post Posted: Thu Jan 09, 2014 6:04 am
/\ Suzistore sell that inlet hose but from memory it isn't cheap.. Something like $170. 8O
Post Posted: Thu Jan 09, 2014 6:36 am
And sierra airboxes are pretty poorly designed and constructed. I don't think I'd spend that coin on a hose to connect to a worthless airboxes.
As to the baleno thing- I agree there's not much in the performance. The baleno is much neater, but only if you're able to do the water pipes neatly, which is a shittonne of work to get right.
Baleno is also coil pack, which makes me all warm and fuzzy.
Vehicle: 89 Sierra Widetrack
Post Posted: Thu Jan 09, 2014 9:17 am
I went with the Baleno engine.
As Steve mentioned If you spend the time on the hoses it will look great. I ran my hose back under the intake using some Camry hoses and a joiner. Some people will run it back over the exhaust but I think that looks terrible
The power gain is also great!
Still sorting a few bit out but it's driving me to work now :)
Vehicle: 2003 Jimny
Post Posted: Thu Jan 09, 2014 4:40 pm
Thanks heaps for the info...hopefully will be picking up the baleno engine on the weekend!
Let the fun begin :D
Vehicle: 92 wt soft top sierra
Post Posted: Sat Jan 25, 2014 10:16 am
Hi Steve you say that the sierra airbox is no good which I agree with and I was wondering what type (make/model) of airbox woupd be better suited for the task
Post Posted: Sat Jan 25, 2014 10:37 am
search.php?keywords=hiace&terms=all&author=gwagensteve&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
I've mentioned my preferred air box once or twice :D
Post Posted: Sat Jan 25, 2014 1:53 pm
Thanks Steve.
Users browsing this forum: No registered users and 21 guests
