It is currently Sat Aug 01, 2026 5:23 pm
Vehicle: Tin Top
Post Posted: Sat Mar 01, 2014 11:15 am
I have no brake pedal, there are no leaks and the lines have been bled.
Have a small pedal after pumping the pedal a few times.
A WT Suzuki Sierra.
What am I missing?
Any help appreciated :)
Post Posted: Sat Mar 01, 2014 1:45 pm
What vehicle? If it is a sierra then they are VERY hard to bleed - I ended up buying a vacuum bleeding pump.
http://www.ebay.com.au/itm/NEW-BRAKE-CL ... 4ea&_uhb=1
Vehicle: Tin Top
Post Posted: Sat Mar 01, 2014 2:39 pm
Thanks Tony, that looks the goods, would definitely make an easier job out of it 8)
Have had a couple of goes at it now and not much pedal until it has been pumped a few times.
Post Posted: Sat Mar 01, 2014 5:48 pm
What have you done to the brake system? (As in why did you need to bleed the lines?)
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sun Mar 02, 2014 12:55 am
ive done the same thing with a handipack spray bottle. just unscrew the spray nozzle and wack the hose on, fill her up with fluid.
pumps the fluid through fine ive found.
Vehicle: Tin Top
Post Posted: Sun Mar 02, 2014 5:56 am
I replaced front n rear brake lines with longer ones.
Have also just done engine change, so had vacuum lines etc
Users browsing this forum: No registered users and 140 guests
